Built 3.8 Engine***LOWER PRICES*** - FirebirdV6.com/CamaroV6.com Message Board
  • Built 3.8 Engine***LOWER PRICES***
    Once again, I must sell my motor and transmission. I've got myself into a financial situation that needs to be taken care of. Most of the key features of the engine are below. Its got just under 1000 miles. The heads are the same ones I had on the stock shortblock except they've been completely rebuilt with new bronze guides and all new valves for this motor. Flow figures can be seen at www.abbottracingheads.com in the GM3800 section. I will include the PCM and wiring harness if someone buys the complete setup. In the case that someone wants only the shortblock, and someone wants the top end, I WILL split it up, but there must be a buyer for both before I tear it down. It made 219rwhp/245rwtq through a 4000 stall converter and a 4L60E transmission on motor, and 362rwhp with a 150hp NX shot. The only track passes it ran a 12.65@106 with transmission shifting issues and going into overdrive. With more TLC on the transmission tune and it would pick up a bunch. It would take over $6500 to duplicate this setup and I'm asking $4000OBO for the engine with all accessories accept maybe the AC compressor. Pictures of the build can be seen here: http://community.webshots.com/album/496188782IaOPgi
    Abbott Racing Engine's built 3.8L
    Abbott Racing Heads "Big Valve Heads" and Ported Intake
    SI 1.86 Intake Valves
    SI 1.55 Exhaust Valves
    T&D Machine 1.7 Ratio Shaft Mount Rockers
    L67 valve covers and spacers for the rockers
    ARH Naturally Aspirated Cam 210/220 .544/.544 112LSA
    Comp 26918 Springs
    Comp 772 Titanium Retainers
    Comp OE-R lifters
    Comp High-Tech Pushrods
    Custom 3.819" CP Flat Top Forged Pistons, 10.3:1 CR, lateral gas ports
    CP 9310 series heavy duty wrist pins
    CP Ring Set w/Steel Top Ring for nitrous
    Rollmaster Double Roller Timing Chain
    Stock rods with polished beams
    Polished stock crank
    Removed Balance Shaft
    ARP Head Studs
    ARP Rod Bolts
    Balanced rotating assembly
    Federal mogul Performance main and rod bearings
    New cam bearings
    Cometic MLS .051" Head Gaskets
    160* Thermostat
    NGK TR6's gapped at .045"
    24lb. Injectors
    TSP Dyno Tuned
    Onto the transmission. I've got a possible buyer but its not set yet so I'll post it on here to guage interest. It's a 4L60E for a 3.8 that was rebuilt just under 1000k miles ago with a TCI Super pro rebuild kit, (i believe thats what its called). Red alto clutches, good steels, TCI trans skat valve body improver(shift kit), upgraded corvette servo. Shifts firm and drives good. I've got over $1250 in the rebuild. Asking $950OBO
    TCI Competition 10" torque converter with a 12" lock-up assembly. Stalls around 4000-4100 behind the above motor. It would stall around 3500-3800 behind a stock motor. I had a 1.77 60' on my only NA pass at the track and a 1.62 60' on the 150shot. It also has just under 1000 miles on it. I'm asking $400 OBO
    If/when all of the above sells, I will have more small parts for sale from the car. If you have any questions regarding anything in the post. Let me know here or at wickedsix@hotmail.com Thanks for looking!
    [ March 16, 2006, 10:21 AM: Message edited by: WickEdSix9838 ]
    Well if you get to the point of getting rid of those headers you built I am first in line!!!
      lol, actually you're third!=)
        Lance...WTF! damn man I would eat this thing up in a heart beat! why you selling it? Damn that's a bummer. Crap wish I had the cash. let me know if you part anything out.
        2002 Firebird<br /> <a href=\"http://www.cardomain.com/ride/2106142/1\" target=\"_blank\">http://www.cardomain.com/ride/2106142/1</a>
          How many miles on the converter?
          2004 CE Corvette 10.86@132mph
          2011 Cadillac CTS-V
          2006 Mitsubishi Eclipse GS
            I thought there was nothing better then the stock converter Shirl?
              Man at least get some good pictures of them then!!!
                Shirl, just under 1000 miles on the converter. It was new with the transmission and motor.
                  Ok, thanks.. sounds like a good deal. I'm looking at another Camaro at the moment, so I'll get back to you if I decide. Thanks.
                  2011 Cadillac CTS-V
                    Prices lowered. I'll take $5200 for everything. This is $.60 on the dollar. It would cost over $8200 for all of it new. It would make your car run guaranteed 12's and very possibly 11's with the spray. Nowhere else will you be able to do it for this small amount of cash!!
