97 Camaro, $3000 with lots of mods - FirebirdV6.com/CamaroV6.com Message Board
  • 97 Camaro, $3000 with lots of mods
    97 Camaro for Sale $3000 / obo
    Want to sell it this week. Seriously.
    Slowly parting out the car -- make offers on any part. If it sells separately, it sells separately. Buy the car and take everything! I've cleaned up the list below, tons of other stuff to say or random parts in storage.
    If you see a () with a price or will sell next to the part, I'll remove and sell it. I will not remove the K member, shocks, torque arm, doors, or engine! Don't even ask, please!
    1997 Chevrolet Camaro
    92,xxx miles
    3.8 V6
    5-Speed
    T-Tops with gray shades
    White
    Gray interior
    Cruise control
    Stock Power locks with two key fobs, alarm
    Manual windows
    Tilt wheel
    Fog lights
    No wrecks
    Exterior:
    Has a front license plate bracket
    Clear front corners, stock in storage
    New-style 16x8 Pontiac wheels (twist-style), stock silver powdercoat
    Kuhmo 245/50/16 711's with great tread
    Exterior part out (drag package for $475 / obo):
    one Goodyear Eagle GT II 235/55/16 with great tread in storage (free)
    Two stock silver powdercoat 16x8 wheels, with centercaps in storage (will sell)
    Two slightly used BFG drag radials in storage (will sell)
    Polished 15x3.5 weld draglite skinnies in storage (will sell)
    ARP studs and Summit lugs and 7/32 spacers in storage (will sell)
    Extra set of t-tops with tan shades in storage (will sell)
    Interior:
    Stock rear seats and belts removed, in storage
    6-point custom weld-in roll bar from Kent Island Speed, with crossbar
    Blue MBA chevy shift knob (will sell), stock in storage
    Converted to a manual bracket on the driver's seat
    Suspension and chassis:
    ProFab K-member, black (stock in storage)
    Front swaybar and brackets removed (stock 30 mm in storage, 32 mm 1LE $45)
    21 mm rear sway bar, poly bushings (stock 17 mm in storage)
    1LE Rear Lower control arms, panhard rod, transmission mount
    MAC bolt-to-tunnel-chassis torque arm
    1LE V8 springs at all four corners (stock front in storage)
    Competition engineering rear drag shocks (stock in storage)
    HAL 1-knob adjustable coilover shocks up front (stock in storage)
    Front upper control arms have poly bushings
    Poly bushings for front lower control arms uninstalled ($20)
    Stock tunnel brace removed, in storage
    Unbalanced Engineering Rag Joint Eliminator
    Driveline:
    SLP Takeoff LSD
    1LE aluminum driveshaft (stock two-piece in storage)
    Spec Stage Three (6-puck) clutch (pressure plate, disc, TO-bearing) in car (stock recently replaced, in storage, wouldn't hold the turbo boost)
    New slave cylinder installed with clutch
    Exhaust:
    Coated pacesetter headers and y-pipe (stock passenger header in storage, y-pipe and cat and etc in storage)
    Tubular manifolds in storage, no y-pipe
    Straight pipe
    SLP loudmouth with the 4 2.5" tips
    Intake:
    Filter on TB (stock intake setup in storage)
    TB spacer
    Extra set of upper and lower intake manifolds in storage ($80)
    Engine:
    EGR removed, in storage ($75)
    Custom egr block off plates on car
    DHP PowerTuner for 97 3.8 f-body in storage, another V6 capability available (will sell $325)
    NGK TR55's installed, with some extras, and some new bosch platinumss in storage
    Summit catch can installed in place of stock
    Recent walmart battery still under replacement warranty
    Hi / lo fan switch in dash
    160* thermo
    Other:
    some other stock parts in storage that you can take!
    Problems:
    Could use a waterpump
    Exhaust leak where y-pipe welded to straightpipe
    Rear brakes need replaced (have new shoes, hardware kit, bearings, etc in storage)
    A/C removed to put in turbo kit, all parts in storage
    The paint has a few minor stains and fiberglass cracks, but then again it's factory and many years old!
    Car will be for pickup or delivery around MD / DC / VA / PA / DE. No checks from foreign countries!
    rwbeas@gmail.com if you're interested or its going to carmax!
    [ September 11, 2005, 06:38 PM: Message edited by: Wicked 3800 V6 ]
    I am so picking that hood up next weekend.
    95 3.4L <br /> <a href=\"http://www.myspace.com/1277388\" target=\"_blank\">http://www.myspace.com/1277388</a> <br /> <a href=\"http://www.cardomain.com/profile/altspacen\" target=\"_blank\">http://www.cardomain.com/profile/altspacen</a> <br /><a href=\"http://groups.myspace.com/camarov6\" target=\"_blank\">http://groups.myspace.com/camarov6</a>
      Right. I made the correction.
        are you parting the car out? If so how much for the SLP loudmouth with the 4 2.5" tips?
        2002 Firebird<br /> <a href=\"http://www.cardomain.com/ride/2106142/1\" target=\"_blank\">http://www.cardomain.com/ride/2106142/1</a>
          Not parting out crucial elements of the car (so don't ask for a door!). Also, the exhaust I'm not removing, since there was welding involved. See my parts post for what I'll sell, so far.
            ok thanks sorry didnt see that you were not going to part it out my bad.
              How much for the lower control arms, if you are removing them?
              Old Car = 12.679 @ 106.5 on 150 dry shot.
              New Car = 2010 3.6l 304hp Camaro
                yeah, how much of the suspension will you part out? i want both your sways and what is a k member?
                The confusion surrounds me <br />change is imminent<br />if I were they<br />we could be great
                  and your lca's and panhard. i want your 1le sh!t
                    OMFG. Not parting out that stuff. I must not have been clear in the original post, I'll fix it. I'll sell what's on the list of parts in the other post.
                      How bout the aluminum driveshaft? Are you willing to sell it since you have the stock one in storage? If so, how much do ya want for the aluminum driveshaft? I call dibs if you're letting it go.
                      ~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
                        I hope nothing bad happened to you and we still see you around..
                          I'm interested in the Stock Air intake if you have it.. Everything from the TB. But I won't need the actual Air Box. How much?
                          My Car: 1994 Camaro 3.4 V6 5-Speed<p><a href=\"http://www.cardomain.com/id/speedyman_2\" target=\"_blank\">My Car</a>
                            Probably not the driveshaft either, at least not at this point. (I said that about a lot of stuff though, earlier).
                            Nothing bad happened, except getting married and moving north.
                            May keep the stock air intake box for a bit until I see about selling the car.
                              Well man, if you decide to sell the aluminum driveshaft, lemme know, I'm interested in it.
