Im looking for a programmable 1997 PCM. I am starting a engine and turbo build and my 96 pcm i have been told can not be programmed. So i am looking let me know if you have one thanks.
97 Programmable PCM
Re: 97 Programmable PCM
Ive got a 97' pcm. I had to plug a new vin# into it so it would work for a manual trans. Are you running a manual? It would also need to be re-tuned before you could use it because it is scaled for #36 injectors.
Originally posted by techsan23 View PostIve got a 97' pcm. I had to plug a new vin# into it so it would work for a manual trans. Are you running a manual? It would also need to be re-tuned before you could use it because it is scaled for #36 injectors.
Your either going to have to find one out of an auto, or have someone flash a vin into the pcm for an auto. I honestly dont know if you could use a newer unit than a 97', but just make sure you dont get one thats designed for drive by wire.
Originally posted by techsan23 View PostYour either going to have to find one out of an auto, or have someone flash a vin into the pcm for an auto. I honestly dont know if you could use a newer unit than a 97', but just make sure you dont get one thats designed for drive by wire.
Originally posted by Unique96Camaro View PostHow would i know if its drive by wire?? And what is that and if i buy yours how do i change it to auto.
Originally posted by techsan23 View PostI believe DBW was used from 99-02 on our cars. Its where the throttle is electronically controlled rather than mechanically driven by a cable. The only way to change a pcm from manual to automatic is to put a vin# into it that is for an auto. I originally got one from pcmforless, and it ended up being for an auto. I had to take it to the dealership and they put a different vin# in it for me. Ive seen people online that do this service for $50-$75. Ive also heard that the pcm needs to be left unlocked in order to access it via hptuners.
