just like the title says...
3.73 gears
96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
yes 3.23and up is series 3. 3.08 and down is series 296 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
Ok...would you be willing to take them off of ebay to sell them to me? If so, how much?Stephen Cruikshank<br /><br />Selling some stuff so all I have left is the FRA, !MAF Screen, whisper lid, Holley PowerShot, 3\" catback, and 160* thermo on the car<br /><br />I Practice Street S.M.A.R.T.S. - do you?
they aren't mine, i was just showing you where some were. but regardless, you cant stop an auction once it started. go to ebay and do a search for 3.73 gears. you will be surprised at how many sets you will find.you could get them cheap, just be careful. try not to get used ones. typically shops dont like to install used gears because they already have a wear pattern. or, you could go to jegs. this is the part number you want.
836-49-0046-1. I recommend you get the install kit before you take it in because the shop will overcharge you for one if you dont already have it.
good luck though.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
The link you gave me was the only one on e-bay for the 7.5" 10 bolt rear end...Stephen Cruikshank<br /><br />Selling some stuff so all I have left is the FRA, !MAF Screen, whisper lid, Holley PowerShot, 3\" catback, and 160* thermo on the car<br /><br />I Practice Street S.M.A.R.T.S. - do you?
the ones from jegs are $194. if you cant find any new ones cheaper, i would just take that route. you will need the ring and pinion, and the install kit. do you already have Lsd???96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
I would suggest the torsen differential as they will never wear out. (No clutches.) Auburn is good too though.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
check out www.gearsrus.com They sell motive gears brand new for 149.99 ..Jeff ..
1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
2002 WS6 T/A.. Bolt ins..448rwhp
2009 G8 GT.. Vararam intake, GXP axleback
1998 Corvette.. Vararam intake, Ti axleback
http://www.fquick.com/slow-v6
