Looking for a set of 36# grandprix injectors...
Go to ClubGP, they almost give sets away there. And I believe the pre 05's are 38 lb'ers.
[ February 10, 2005, 01:37 AM: Message edited by: Rob 94Hawk 319 ]Rob<br /><a href=\"http://www.robshawk.com\" target=\"_blank\">1994 Firehawk#319</a><br />11.83@120.61<br /><a href=\"http://www.RobsHawk.com/MODLIST.txt\" target=\"_blank\">Slightly Modified</a><br /><a href=\"http://www.RobsHawk.com/Jana/Camaro/\" target=\"_blank\">1996 Blown V6</a><br /><a href=\"http://www.RobsHawk.com/NewTruck/images/100_0011.jpg\" target=\"_blank\">2004 Silverado</a><br /><a href=\"http://www.RobsHawk.com/Trailblazer/TrailblazerSm1.jpg\" target=\"_blank\">2002 Trailblazer</a><br /><a href=\"http://www.SDFB.org\" target=\"_blank\">San Diego F-Bodies</a>
Originally posted by Superv6bird:
Thanks for the help. I've got a set of 6 36# injectors on the way from ED Morad.2000 turbo/intercooled M5 Black Firebird<br />349.5hp and 415.3tq @ 4400rpms
Originally posted by Radcat:
</font><blockquote>quote:</font><hr />Originally posted by Superv6bird:
Thanks for the help. I've got a set of 6 36# injectors on the way from ED Morad.1997 Supercharged Firebird<br />14.01@99.7mph 2.1 60ft.
If you get GTP injectors you will have to modify your fuel rail to get them to fit.Rob<br /><a href=\"http://www.robshawk.com\" target=\"_blank\">1994 Firehawk#319</a><br />11.83@120.61<br /><a href=\"http://www.RobsHawk.com/MODLIST.txt\" target=\"_blank\">Slightly Modified</a><br /><a href=\"http://www.RobsHawk.com/Jana/Camaro/\" target=\"_blank\">1996 Blown V6</a><br /><a href=\"http://www.RobsHawk.com/NewTruck/images/100_0011.jpg\" target=\"_blank\">2004 Silverado</a><br /><a href=\"http://www.RobsHawk.com/Trailblazer/TrailblazerSm1.jpg\" target=\"_blank\">2002 Trailblazer</a><br /><a href=\"http://www.SDFB.org\" target=\"_blank\">San Diego F-Bodies</a>
I believe it was 2000+ that you have to modify the rail and get different electrical connectors. The 2000+ cars came with Delphi injectors. They are taller and have a different connector then the GTP injectors. You have to shorten the supports on the rail and splice in new connectors. I am in the middle of the modification right now. Should be a PITA.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
Originally posted by arthansen:
I believe it was 2000+ that you have to modify the rail and get different electrical connectors. The 2000+ cars came with Delphi injectors. They are taller and have a different connector then the GTP injectors. You have to shorten the supports on the rail and splice in new connectors. I am in the middle of the modification right now. Should be a PITA.2000 turbo/intercooled M5 Black Firebird<br />349.5hp and 415.3tq @ 4400rpms
