anyone have some? hopefully flow matched
65# injectors
Re: 65# injectors
There are 8 ones over here on AZFBA.com for $265 says he ran 10 gallons through them. He lists them as 60lb injectors but that is what our cars with 65lb injectors are rated from 60lbs of then go up from there when using Hptuners. Different fuel pressure systems.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: 65# injectors
looking for 18-20 at the track. gonna find a spare motor before I run that though. will be run at 7-9 psi dd for nowCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
Re: 65# injectors
I have 6 new 65lb Motron injectors I bought from ZZP, but will be seeing if I need them for my turbo setup , I think I will since I have only 36lb injectors in there now running N/A. If I don't need them I will sell them but I will have to see if I max the 36lb injectors first. I'm planning on running 9-10 PSI DD and maybe 12-15 at the track. So will see, everyone says I'll need the 65lb injectors(actually rated 60lbs) but we'll see how it goes.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: 65# injectors
ya I was thinking about doing lucas 42.5s. They would be enough to hold the boost I'm looking for, but I figure once this motor blows I'm going with an ls1, so I would be better off with the larger injectors. BTW, I would be turboing the ls1 afterwardsCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
Re: 65# injectors
well i found injectors, thanks every1. I bought 36# for very cheap. May go larger later, but I need to start saving money for other things :(Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
