this is kind off topic but does anyone know if a 2000 jetta is hubcentric or lugcentric? and if pretty much any 5x 100 rims would fit on it. long story short im getting rims off a calvalier to put on my girlfriends jetta for snow tires
vw rim question
Re: vw rim question
Originally posted by Mogobs30th View PostNot sure what exactly you mean, but from what I can understand, the wheels on a VW wont work because I *believe* they use lugbolts instead of lugnuts.
I would think that as long as the bolt pattern and offset is the same, then it should not be an issue. As far as being hubcentric, I know there are plastic caps you can get to make the center fit tight with the hub.
Re: vw rim question
thx for the help i talked to one of my friends today and he said they work just fine i just need sum hub rings and lug bolts or nuts makes no difference what so ever except that its a pain in the *** cause u have to hold the wheel while u put the lug in
Re: vw rim question
Originally posted by LETZRIDE View Postwhy would this not make the wheels from a cavalier not fit a VW? The rim still has holes in it, so whether you put it on studs, or put lug bolts through the holes into the hub there, I dont see why that should make a difference?
I would think that as long as the bolt pattern and offset is the same, then it should not be an issue. As far as being hubcentric, I know there are plastic caps you can get to make the center fit tight with the hub.1995 Pontiac Firebird
Re: vw rim question
Originally posted by Mogobs30th View PostThe angle on the lip of the lugbolt may be different compared to the angle of the lugnut, due to the fact that the wheel is coming off a foreign car to a domestic. The wheel in turn will not seat properly, creating a wobble, and eventually breaking loose a stud on the Cavalier.
