vw rim question - FirebirdV6.com/CamaroV6.com Message Board
vw rim question
  • vw rim question
    this is kind off topic but does anyone know if a 2000 jetta is hubcentric or lugcentric? and if pretty much any 5x 100 rims would fit on it. long story short im getting rims off a calvalier to put on my girlfriends jetta for snow tires
    Re: vw rim question
    Not sure what exactly you mean, but from what I can understand, the wheels on a VW wont work because I *believe* they use lugbolts instead of lugnuts.
    1995 Pontiac Firebird
      Re: vw rim question
      u r correct Wes
      87 Firebird RIP
      96 Camaro RS RIP
      94 Patriot Red 1LE Z28 - Sold
      02 WS6 TA - Sold
        Re: vw rim question
        why would this not make the wheels from a cavalier not fit a VW? The rim still has holes in it, so whether you put it on studs, or put lug bolts through the holes into the hub there, I dont see why that should make a difference?
        I would think that as long as the bolt pattern and offset is the same, then it should not be an issue. As far as being hubcentric, I know there are plastic caps you can get to make the center fit tight with the hub.
          Re: vw rim question
          Id be willing to bet they won't work.
          *Matt
            Re: vw rim question
            thx for the help i talked to one of my friends today and he said they work just fine i just need sum hub rings and lug bolts or nuts makes no difference what so ever except that its a pain in the *** cause u have to hold the wheel while u put the lug in
              Re: vw rim question
              its not that bad to change the wheels on vws. takes 5 mins
              87 Firebird RIP
              96 Camaro RS RIP
              02 WS6 TA - Sold
                Re: vw rim question
                The angle on the lip of the lugbolt may be different compared to the angle of the lugnut, due to the fact that the wheel is coming off a foreign car to a domestic. The wheel in turn will not seat properly, creating a wobble, and eventually breaking loose a stud on the Cavalier.
                  Re: vw rim question
                  without seeing it I dunno, but I would think that you may be able to get a lugbut setup similar to that that I have on the Weld Wheels, one with a washer which should take care of any lips and spread the pressure out?
