I have one of the most inefficient condos in the world and at this point in time don't have the money to replace windows, door, ac unit, etc. So I decided to go with this instead, I'm sure some of you have seen it, so far it gives a decent amount of cooling. With fresh ice it gives about a 10-15 degree drop in the air that it's blowing compared to the ambient temp. It gets cold enough that I had to throw a towel under the fan because there was so much condensation. I spent a little extra on the hose and connections so right now it consists of 20' copper tubing, compression fittings, 20' hose cut in half that would normally be used for freezer connections and a submersible 120 gph pump. The one piece that could stand to be improved is the cooler but until I ran it I wasn't going to spend a bunch of money there.
