I have one of the most inefficient condos in the world and at this point in time don't have the money to replace windows, door, ac unit, etc. So I decided to go with this instead, I'm sure some of you have seen it, so far it gives a decent amount of cooling. With fresh ice it gives about a 10-15 degree drop in the air that it's blowing compared to the ambient temp. It gets cold enough that I had to throw a towel under the fan because there was so much condensation. I spent a little extra on the hose and connections so right now it consists of 20' copper tubing, compression fittings, 20' hose cut in half that would normally be used for freezer connections and a submersible 120 gph pump. The one piece that could stand to be improved is the cooler but until I ran it I wasn't going to spend a bunch of money there.
Redneck AC
Re: Redneck AC
Do you have a write-up? Mods, please sticky this. WIN. :P#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
Re: Redneck AC
man why didnt i think of crap like this the last time our a/c went out lol. this just got book marked just in case haha
Follow me!
Or this
Re: Redneck AC
Originally posted by 02silverbird View Postbe careful that the condensation doesn't go in the motor coil of the fan!
But other than that not bad way to use the ol' nogen! :)
Originally posted by unvmyrs View PostDo you have a write-up? Mods, please sticky this. WIN. :P
Like I said I spent a little extra on the hoses and connections just for added insulation and to eliminate leaking. Here's a couple more pics to give you an idea of the pump setup and the connections.
This could use some improvement but it works for now.
The next thing I might do is look at adding 15' of copper tubing to the back and getting some extra cooling. This is getting as bad as modding a car.Let's flip a coin. Heads I get tail, Tails I get head.
Re: Redneck AC
Originally posted by Tom Rs View Postwhat did this cost ? i can get a new a/c for about a hundred, thats why i ask
In my case it wouldn't matter if I service or repair the ac because there's still all the leaks. Until I fix those leaks (door, windows, 20 year old ac) I'm not going to throw money away cooling the whole condo when all I care about is cooling me.Let's flip a coin. Heads I get tail, Tails I get head.
Re: Redneck AC
after looking at that guys vs yours..your way is a hell of alot better IMO.
Follow me!
Or this
Re: Redneck AC
next... cut some holes in the side of your fridge, and put the water in the fridge and run your pipes through there... then you don't have to keep making ice lolRebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
Re: Redneck AC
whatever works!
once in my acura i didnt have heat in the winter, so i put a low voltage space heater in the backseat and made a cardboard box for it so i wouldnt melt the seats and plugged it up into the cigarette lighter dc converter. tada - warm air. :)Dave:
00 Supercharged Camaro - RIP
97 Turbo Camaro - Sold
Re: Redneck AC
Originally posted by vanbibber View Postafter looking at that guys vs yours..your way is a hell of alot better IMO.
Originally posted by T-Mill View Postnext... cut some holes in the side of your fridge, and put the water in the fridge and run your pipes through there... then you don't have to keep making ice lol
Originally posted by steddy View PostI like it! All I wonder is how much cheaper it is to run than a window ac unit? You (or someone) may have come up with something, given the current state of economics. Very cool!
Next up is gonna be adding another 20' of copper to the back and have the fan push and pull the cold air. Should be interesting.Let's flip a coin. Heads I get tail, Tails I get head.
