trading to an lt1 - FirebirdV6.com/CamaroV6.com Message Board
trading to an lt1
  • #16
    Re: trading to an lt1
    hey im sure this site has been linked around here somewhere. anyway i use it all the time when im looking to see the build specs on potential cars im interested in. i went ahead and pulled your up. looks like a 94 good thing you got the vin. someone trying to burn you?
    http://www.compnine.com/
    Vehicle: FIREBIRD 2 DR
    Year: 1994
    Build Date: 1993-09-28
    UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
    50,718
    UK3 ELECTRONIC SYSTEM,ACCESSORY CONTROL ELEK ACSRY CONT SYS(UK3)
    37,318
    UT6 RADIO,AM/FM STEREO,CASSETTE,EQUALIZER,ETR,CLOCK STEREO CASSETTE/EQLZR(UT6)
    27,668
    UW2 SPEAKER SYSTEM -10, QUAD FRT DR MTD, DUAL RR SAIL PNL, AMPLIFIER 10 SPKR SYS(UW2)
    37,169
    U73 ANTENNA,FIXED FIXED ANT(U73)
    48,565
    V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
    46,990
    WS9 MODEL CONVERSION FORMULA(MERCHANDISING OPTION) FORMULA(WS9)
    22,570
    Y83 TRANS AM PACKAGE(MERCHANDISING OPTION) TRANS AM(Y83)
    7,532
    1SA PACKAGE-OPTION 01 (1SA)
    13,717
    17P WHEEL COLOR-SILVER (17P)
    20,144
    48Q MOLDING COLOR DK YELLOW GREEN MET (91) (48Q)
    6,423
    48U EXTERIOR COLOR,PRIMARY (48U)
    EXTERIOR COLOR,PRIMARY,BLACK EMERALD MET (48U)
    EXTERIOR COLOR,PRIMARY,DK RED (48U)
    EXTERIOR COLOR,PRIMARY,DK YELLOW GREEN METALLIC (48U)
    7,098
    6HE COMPONENT FRT LH COMPUTER SEL SUSP (6HE) SUSP(6HE)
    5,778
    64I INTERIOR TRIM,LIGHT BEIGE (64I)
    6,341
    642 TRIM COMBINATION LEATHER, LT BEIGE (642)
    2,529
    7HE COMPONENT FRT RH COMPUTER SEL SUSP SUSP(7HE)
    5,778
    8TH COMPONENT RR LH COMPUTER SEL SUSP (8TH) SUSP(8TH)
    13,678
    9T. Unk. 10,490
    AAA Unk. 45,086
    AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
    50,718
    AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)
    SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING"ULTIMA"INCLUDES SEAT ADJ(USED WITH TRANS AN Y84) RECL FRT BKT ST(AQ9)
    7,532
    AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYS)(INCL REM HATCH CTL) REMOTE ENTRY LK CONT(AU0)
    LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
    34,838
    AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
    46,325
    A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
    46,074
    B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35)
    46,363
    B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
    46,807
    CC1 ROOF,HATCH,REMOVABLE PANELS,GLASS HATCH RF(CC1)
    23,896
    C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
    38,692
    C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
    50,505
    DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
    39,155
    DL5 DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
    45,086
    FE2 SUSPENSION SYSTEM,RIDE AND HANDLING RIDE & HANDLING SUSP(FE2)
    22,570
    FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
    42,750
    GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5)
    36,806
    G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
    24,381
    IL2 TRIM,INTERIOR DESIGN (IL2)
    4,667
    J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
    24,381
    KC4 COOLING SYSTEM,ENGINE OIL ENG OIL CLG(KC4)
    13,317
    KG7 GENERATOR 125 AMP 125 AMP(KG7)
    4,397
    K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
    45,475
    LT1 ENGINE-GAS, 8 CYL, 5.7L(5.7P),MFI,HO 5.7P(LT1)
    22,570
    MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
    40,122
    M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
    40,122
    NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
    46,108
    NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
    37,318
    PW7 WHEEL,16X8,STYLED(ALUMINUM)(SUPERLIGHT) STYLED AL WHL(PW7)
    22,570
    QLC TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC)
    13,677
    STE PLANT CODE- ST THERESE, PQ, GM OF CANADA ST THERESE,GM OF CANADA PLANT CODE(STE)
    50,718
    T96 LAMP,FRONT FOG FRT FOG LP(T96)
    LAMP,FRONT FOG(EXPORT) FRT FOG LP(T96)
    LAMP,FRONT FOG(USED WITH TOURING YP6) FRT FOG LP(T96)
    12,6931
    There are 15 1994 FIREBIRD 2 DR vehicles (0.030%) matching your exact options list. There are 35 (0.069%) with at least as many options.
    lastly if im in your position i would NOT trade. you have been given a song and dance by the seller and it just seems shady. remember if its to good to be true...just my 2 cents. good luck bro.
    • #17
      This whole deal sounds like ****.....94 for 94, with broken parts on the LT1, isn't worth it. The engine may have miles on it that you don't know about. Starting an engine isn't a good way to tell of its life, or mechanical faults.
      1995 Pontiac Firebird
      • #18
        Take a pass on the parts car.JMHO
        There are great deals out there to had don't jump at the first one you see.
        • #19
          Yeah, I looked up on that site, said my maro was a 1 of 1. I'm still not sure what I'm gonna do. I can always rebuild the engine and stuff. I never really drive the maro anymore. It just sits there, no insurance. I'm gonna miss it like hell, but I could definitely fix up the trans am and make it nice, it does have leather interior. I kind of want a project car. I know I sound crazy, I can't explain it though.
          • #20
            For what you'd spend on that car after you traded, you can swap in an LT1 in YOUR car.
            Or sell your car, Buy an LT1 car. Dime a dozen these days.
            -Jarred '70 Pontiac LeMans | '89 Firebird Formula 350
            • #21
              All I'd have to buy is a windshield and re do the leather driver seat. He ahs EVERYTHING to put it back together.
              • #22
                • #23
                  Frame damage?
                  • #24
                    just that front piece, but it was replaced, hence the red. The car was originally green and was painted black. I have a fun weekend to look forward to, huh? lol
                    • #25
                      You didn't buy that thing did you?
                      • #26
                        traded the 3.4 to it.
                        • #27
                          Man'o man.
                          • #28
                            As I stated previously, I really wanted a project car. It's already set up for a v8. I don't have to worry about switching rear ends and wiring harness and everything. I know a lot of people on here won't see the logic in what I want, if there is any. I will admit I didn't have the greatest 6 on here or anything. It needed a few things and he was willing to trade straight up for it. Lt1's are cheap if I end up having to get another for the car. But, it's going to be taken to the track and used for weekend enjoyment. I could sell things off the trans am and come out even for what the camaro was worth.
                            • #29
                              wow...after the guy lied to you...and hes giving you a car in pieces...and only God knows what else...you still made the trade?
                              If for some unknown godly reason I was looking at that car in that state, and still considering it...I woulda walked the moment I found out it was a 94 and he lied about it...cause god knows what else he lied about...
                              Im assuming you havent driven the car? that thing could very well be a ticking time bomb just waiting to blow up...
                              • #30
                                When I saw it I knew it wasn't a 99 like he had said, he was under the impression the body was a 99 because of the front end swap. I also gave it the benefit of the doubt.
