So i installed everything yesterday. Clutch, new pilot bearing, and upgraded 01-02 slave with new throwout bearing. It took me about 7 hours to do by myself. I have never taken a t56 out till now and it was very strait forward i must say. And the difference is night and day. My old ls1 clutch was pretty shot and didn't acelerate till the pedal was almost completely released. This one has a lot more control and starts accelerating immediately upon pedal release. Just WOW. Also got my red umi strut tower brace installed which took all of 2 minutes.,. Fun times...
ls7 clutch installed...
#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>Tags: None
Re: ls7 clutch installed...
<-- eats cookie. Thanks Matt#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
You mean shock tower brace. My STB actually made a pretty noticeable difference in everyday driving, even though most will swear it's a visual mod only.
Sounds good though, I saw the title, and before I saw the poster I was thinking wth (and how) would you put an LS7 clutch on a 6'r. Makes sense though now.
ls1tech is where I bought it, for 275 shipped. :D#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
$275 + 7hrs = Cool investment in DIY repair. Invaluable for sure.
I just saw my friend spend $800 for a stock '97 3.8L Firebird stock clutch R&R with the same (non LS7) necessary parts you listed.
Does the LS7 clutch kit come with R&R instructions? I'm interested in saving some money for next year.Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
Alex,
Yeah it was a good investment overall. Saved a lot of money doing the work myself. It didn't come with instructions. It's a simple swap. No special parts or adapters needed. Make sure if you get the clutch you get the ls2/ls7 flywheel too.#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
Just want to confirm, the LT1 and LS1 are the same T-56 trannys so an LS7 clutch should work in my application as well?
Same tranny with diff bell housings. The hydraulics are diff though. You've got a hydraulic slave cylinder whereas the LS1 has a hydraulic throw out bearing. If it is possible there would be more too it than just swapping the clutch and flywheel.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...1 day ago
