I use 20/50 normally, since it gets 115-120 temps in summer the thicker oil helps against bearing failure and wear. I picked up the 10W40 for cheaper thats why I bought a case of it. It will never drop below 20 degrees or 10 degrees.
There is 20w50 amsoil carries as well steve...using thicker oil may or may not help you with bearing failure though...I believe that all depends on what your tolerances are...tighter tolerances may not allow a thicker oil to get in there...irrc the first number (I.e the 10 in 10w30) is the tempetature factor...it's the second number "40" in my example that is the weight/thickness
1. Castrol GTX 10w30. Cheap and works just as well, especially since it still leaks.
2. Hankook v12 Evo.
3. Borla
4. Hardtop. My other car already has t-tops.
5. Stealth, I guess. My car's slow and quiet.
'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
1)Valvoline with a bosh oil filter (AVOID FRAM!!!!!!)
2)Michelin's or Goodyears
3)Borla with K&N airfilter
4)T-Top's although I prefer a Targa top
5)My blue accents which will soon be converted to the final color by tomorrow :)
I know Amsoil has the 20W50 , I wanted a thinner oil for the turbo I thick the 40W will be better off for it and protect the engine at the same time.
1) Oil. Royal Purple when I have the $$$, valavoline 1/2 & 1/2 otherwise
2) Tires Kuhmo
3) Exhaust Flowmaster
4) Conv/T-tops T-tops
5) Annonce your presence or stealthy stealth until you floor it,
2013 Ram 1500 Big Horn
94 comero 3.4
1) Penzoil platinum fully synthetic/K&N Filter
2) Khumo Ecsta (way surprised at the traction in rain or dry)
3) Pacestter ceramic, 3" stepped down into 2 1/2 toward toward the rear. My first choice is Dynomax (though I'm currently running a magnaflow).
4) T-tops
5) A little too raspy for my taste, but hey, it's stainless, gained a dyno'd 5 hp (numbers between dynomax & Magna), so no worries.
