Dyno Time - FirebirdV6.com/CamaroV6.com Message Board
Dyno Time
  • Dyno Time
    Dunno where to put this, so the lounge can get some action for a bit. Looking to hit the dyno in the up coming weekends (not sure exactly which one yet) What do you guys think she's gunna lay down?
    Engine
    Custom cam 230/240 .512/.512 113LSA @0.060
    P&P heads 1.9" intake 1.57" exhaust manley valves
    Full bolt ons exhaust/headers/short ram intake
    Electric water pump
    approximately 9:9:1 Compression ratio
    Drivetrain
    aluminum driveshaft
    Ford 8.8 rear end with 4.10 gears
    Automatic transmission
    rebuilt tranny with a vette servo
    3200 TCI stall converter
    Don't think I'm missing anything...Car will be going on with the 18" C5 rims in the back with nitto extreme 555's 275/40R18 tires if that makes a difference.
    Any takers?
    Background info: On the old ARH cam (210/220 .512/.512 112LSA @0.060) the car ran a best of 13.7 cam only with about 28-30* of timing
    With the heads done and getting a knock (probably the bearing going) she did 13.6 heads/cam on the spun bearing with 15-17* of timing.
    ^^ both of those were also on about a 9:5:1-9:6:1 compression ratio.
    Re: Dyno Time
    182 hp 201 tq? lol
      Re: Dyno Time
      200hp/ 215 TQ only because of the stall.
        Re: Dyno Time
        stalls fairly tight...2.1 STR
          Re: Dyno Time
          192/210
          Dave:
          00 Supercharged Camaro - RIP
          97 Turbo Camaro - Sold
            Re: Dyno Time
            If you lock the stall I would say 220hp / 240 TQ
              Re: Dyno Time
              not a lockable stall, unless I want it in pieces at the end of the run...
                Re: Dyno Time
                Thats true , I forgot locking your stall is hard on the stall, not worth the hazzle.
                  Re: Dyno Time
                  I should have asked this earlier... but who is tuning it? Makes all the difference.
                  Dave:
                    Re: Dyno Time
                    I believe its tuned by LetZride already.
                      Re: Dyno Time
                      Do you have some 16"s for the dyno run?
                      That will free up a few ponies instead of turning those heavy 18"s.
                      I am going with 245HP 248TQ
                        Re: Dyno Time
                        doubtful the 18s will do anything... and pretty high wager! I think mine may be low..
                        Dave:
                          Re: Dyno Time
                          Rolling resistance,I just had my 99 TA dynoed 312 HP 325 TQ the dyno operator told me the rolling resistance might be worth 5-10 HP depending on tire width.
                          Mikes car has run 13.7.
                          To run a 13.7 in my 94TA I had 278HP and 328TQ.
                          Mike 60fts better than my TA ever did 2.0's were the norm.
                          Plus he has weight reduction and thats what gets him the 13.7,thats why I put it at 240HP or so.
                            Re: Dyno Time
                            I'd guess 215/220 (hp/tq).
                              Re: Dyno Time
                              Done by me ;)
                              Tom, I do have the drag rims/slicks...maybe I'll throw on the Weld's when I go...we'll see.
