hp goal question - FirebirdV6.com/CamaroV6.com Message Board
hp goal question
  • #31
    Re: hp goal question
    okay here we go
    T56 swap
    9in with 4.11's
    Lower control arms, Tq arm, Subframe Connectors, Pan hard bar.
    Tubular K-member
    Aluminum Driveshaft
    Headers, LS1 style y-pipe
    Forged 3.8 or l26 or rebuild
    ported heads, blower cam, and port matched intake
    Supercharger
    Tune
    Upgrade fuel system for Charger
    High flow oil pump
    Valve springs, retainers, Valves, pushrods, lifters
    springs,shocks,sway bar,c5 brake kit
    wheels 17" front 18" rear
    maybe watts link
    • #32
      Originally posted by 3.8lcoty View Post
      okay here we go
      Forged 3.8 with ported heads, blower cam, and port matched intake
      maybe watts link
      Just curious, when you say "Forged 3.8" what are you referring to?
      Also, can you explain why a watts linkage is superior to a panhard rod?
      • #33
        idk all the guys online says its great and it also helps keeping the car from scooting side ways on the strip
        • #34
          http://intense-racing.com/Merchant2/...de=3800_Engine
          • #35
            You could rebuild your current motor and come under cheaper than buying a short block.
            • #36
              thats one thing im scared to mess with because one mistake and then your done,if i could find someone who will not charge the crap out of me i would pay someone
              • #37
                could you build the 10 bolt to handle more power or is it a waste of money
                • #38
                  Waste of money, go with a 12 bolt or 9 inch or 8.5"
                  • #39
                    which is the best for the money in your opinion
                    • #40
                      9 inch seems to hold more power so that would be my guess.
                      • #41
                        have you used any of them
                        • #42
                          Do not build a 10 bolt.. Tried that and it broke. Spent 1000.00 on it using a Eaton Posi, Moser Axles, a rear end T/A cover.
                          Would my V6 with a tune alone be able to take my WS6. I would have to say yes. My WS6 only made 440rwtq and with a tune I am sure my V6 would have surpased that number. My V6 weighed about 200 lbs less then my WS6 as well. If I had a Built Rear and Built tranny with slicks and launched on the Juice Holy cow. As long as the Bottle pressure stayed above 1000 PSI the entire 1/4 Miles pass then yes I think with just a tune my V6 would beat my WS6 in a drag race. My V6 motor was built to handle over 600hp as well so Just for fun I probably would have put a 175-200 Shot and try to make over 500 rwhp.
                          All this talk really makes me miss my car!! Thanks guys. Gosh darn V6ers!!
                          Jeff ..
                          1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
                          2002 WS6 T/A.. Bolt ins..448rwhp
                          2009 G8 GT.. Vararam intake, GXP axleback
                          1998 Corvette.. Vararam intake, Ti axleback
                          http://www.fquick.com/slow-v6
                          • #43
                            If thats what you want to do then thats not a bad deal. Think I spent 5000 for a machine shop to put together my motor including parts which I used the diamond 9.8.1 pistons and L32 rods. This is a major project with lots of money that when you do it you will not be able to get back 80% of what you put into it if you decide down the road to sell. I know you will probably say I will never sell my car. Thats what I said but 3 yrs later I ended up trading it in fo 3500.00 bucks with a built motor!!
                            Jeff ..
                            • #44
                              So is it possible for a fully stock 3.8 with a blower and supporting fuel mods to make over 400 rwhp?
                              Jeff ..
                              • #45
                                haha idk maybe with a tune
