Shift points - FirebirdV6.com/CamaroV6.com Message Board
Shift points
  • Shift points
    What will me engine be SAFE to spin up to?
    GT2 cam, comp oe lifters (not the oe-r's), comp hi-tech push rods, comp rocker bolts and arp head studs.
    Re: Shift points
    I would say 6100-6200 you'll be fine. What lb spings you running 105lb?
      Re: Shift points
      Yeah forgot to say, 105#. My pcmforless tune only had me a 5700 last time. Planning on a street tune this time and I dont want my tuner going too crazy on them lol
        Re: Shift points
        You'll be good at 6200, most newer 3.8's have it set at 6000 . I tuned a 00' Firebird 3.8 with the GT2 cam and it went pretty well. I bumped the rev limiter and added a few degress of timing up top , seemed to work very well. Also added extra fuel throughout the rpms. I would add a wideband O2 sensor to be safe.
          Re: Shift points
          Yeah the guy who's gonna be tuning it said he uses a wide band. JusTune is gonna tune it, he's supposed to be the man around here with LS/ LT's. Im sure he can handle a 3.8.
            Re: Shift points
            Man that just seems high lol
            The ZZP site has this on both the Comp OE-R lifters and LS7 lifters- "These lifters are almost required for any 3800 car shifting above 6000rpm because they help with the typical 5600rpm dip".
            Sure its safe to go that high on just Comp OE's? Im so retarded for not buying the LS7 lifters, but I hear GM uses those in like everything now. Anyway of knowing when exactly they started? This engine is 2006 L26, I wonder if it already has those lifters and I could return the Comps.
            Edit
            Just emailed ZZ, that wasn't much help- "Hard to say. Stock balancer isn’t rated over 6k rpm but people still rev past that. SFI balancer would be needed to be completely safe"
              Re: Shift points
              I think you'll be safe.
