Insidethreat07 2001 Camaro - FirebirdV6.com/CamaroV6.com Message Board
  • #31
    Re: Insidethreat07 2001 Camaro
    Originally posted by insidethreat07 View Post
    I think what ill prob end up doing is painting it black and polishing the raised letters. I think it will look pretty good
    What I did was use a wire wheel before I painted to make it all shiny, then covered it in tape and used a razor blade to cut around the letters, then painted it and pulled the tape off.
    Team NoVa
    • #32
      Did this earlier in the week, Cleaned inside and out of my wheels, repainted my calipers, Camaro on calipers. and roatated my tires.
      • #33
        how did you get the camaro words in there i want to do that but with my bird
        • #34
          http://www.bfranker.badz28.com/vinyl/vinyl.htm
          Not sure if he has anything for a firebird
          EDIT: he does ust have to scroll down farther lol
          • #35
            thanks man you saved me allot of money, the place a went were charging like 50 percent more of what he does
            • #36
              No problem :rock::banana:
              • #37
                Might be getting this as a late Christmas present to myself:
                http://www.foundersperformance.com/p...elocation-kit/
                http://www.foundersperformance.com/p...nhard-Bar.html
                • #38
                  On a side note would I need The PHR relocation if Im putting a 3" over the axle pipe on.
                  • #39
                    Ive got stock suspension minus shocks and LCA relocation brackets and 3" single shot with no issues with the exhaust hitting the panhard bar. Even when I didnt have the LCA relocs it cleared fine.
                    This is on a car with a hearthrob midpipe and over the axle pipe and home made S pipe, brackets, and muffler stuff. Its far from perfect and fits fine. It's close but I wouldnt waste the money.
                    And for tubular LCA's and panhard bar I wouldnt spend the money unless you want to keep the business running. My stock stuff is fine running 1.93 60ft's and my cousins 00 Z28 cuts consistant 1.60's on stock stuff. Money is better spent on strano springs, good shocks, and LCA relocs. You can replace the LCA bushings (I did, had horrible wheel hop and threw some on just to be safe when I put in the LCA relocs) but if you don't have wheel hop theres nothing wrong with stock stuff.
                    Granted Im cheap though so....
                    Its hard to see but theres room.
                    • #40
                      I have 2 2-1/2" pipes squeezed through with stock lca's and phb, eibach pro-kit springs. There's plenty of room for a single 3" over the axle..
                      aka FreedStyle
                      Chaddrich Freed
                      (1 of 443) 2002 SLP Firebird GT #107 (244rwhp/254rwtq naturally aspirated)
                      2008 Silverado Crew Cab 5.3L 4x4
                      • #41
                        Best 60' I ever had was a 2.2x
                        I dont ever plan on lowering my V6 or anything like that lol
                        Would non-adjustable PHR be good for my car? No lowering or really wide tire plans
                        • #42
                          LCA's would help you better , you could go with a non-adjustable panhard rod and still be good.
                          • #43
                            Non-adjust LCAs as well?
                            • #44
                              Justy ordered myself a late Christmas present
                              http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=7_138_97&pr oducts_id=140
                              Also did the heater hose mod to the rear
                              • #45
                                Thats sweet. They come with polyurethane bushings installed. An extra plus
