Check car-part.com
A quick search of the Dallas area showed several under $1,000 with less than 30,000 miles. That's how I found the one that I WAS going to buy, but I stumbled on the 58k mile motor I bought for $500. Just wait to buy the engine until you're ready, but keep some cash on hand and ready in case a good deal does pop up on craigslist.
And you want an '05+ l26. They all have the stronger bottom ends.
Yea that's why I want and 05 or newer. But wouldn't the l36 just be fine also?
What I'm trying to achive is an engine that can make the car drift. With some wheight reduction done the the inside.
You probably didn't type it in right, you shoulln't have to put in any personal information. An L36 would be fine, but good luck finding one with low miles. The L26 replaced it in the early 2000's. They are the same engine, just the L26 had slightly different heads and some '04 and all '05+ had the powdered metal rods.
It should have a search box right on the homepage. You should be able to select:
-Year
-Make/model
-Part
-State
-Sort by
-Zip code
The next screen should ask to select the vin, then it should show you everything in thr area you searched. I've used the site from my computer, tablet, and phone and haven't had any issues.
-Year
-Make/model
-Part
-State
-Sort by
-Zip code
Yea but after I put my zip in it redirects me to fill out my info...just my adresss and number
Thanks by the way for the link I found several engines close to me with less than 22k.
Quick question by the way I've done my research on these engines and according to it . Any engine manufacture from 05 to 08 has the stronger bottom end correct no mater from what car it came from if its a grand prix , buick lacrosse or a Lucerne?
All right guys so today my engine literaly crapped out on me after coming home from a local car cruise n hang I went to. I bearly made it home but that engine is out. It sounds like an exhaust valve stay slightly open and missfires. So I'm not dribing it anymore at all. Not untill I have all my parts for the engine build and then I will drive it .5 miles away to a family memebers house where hopefully it will take me 2days to swap it in when the engine is done. Anyways I have some video of what it sounds like at idle and some pictures from the small meet I was at before it crapped out.
4 days ago
