Have any of you used MMO. I used it on my wife's VW tonight. I poured 4 ounce in the tank and 5 ounce in the crankcase. It really smoothed out the rough idling and it felt like it gain some HP, maybe because the compression got better.
Marvel Mystery Oil
I remember hearing about it, but don’t know much about it. Is it like a seafoam type deal?
Never heard of it. Does sound like Seafoam.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Let us know how it goes.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
Yes, I just used it for the first time earlier this year.
It's similar to Seafoam. It cleans as it circulates.
The tank of gas I used it in got noticeably good mileage in the middle of a run of bad mileage fill-ups.
I also used it during the oil change and plan on doing so again next time. (I have a case of it in the garage.)
I haven't noticed any negative results at all.
- 1 like
Originally posted by Namrepus28 View PostYes, I just used it for the first time earlier this year.
Since you're only running a relatively small percentage (20% max I think) of the volume as MMO, you can run it the full length of time and include it in every oil change. (Although I think only running it occasionally is all you'd need.)
I usually go 10,000 km between changes using full synthetic. I'm a fair bit into this run so far and haven't noticed anything negative or odd engine-wise.
If you were, say, rebuilding parts of an engine and putting it back together you might want to flush it out with a greater percentage of MMO and change it very shortly after starting it back up and circulating.
- 1 like
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...3 days ago
