hey there strangers! - FirebirdV6.com/CamaroV6.com Message Board
  • hey there strangers!
    been a while but looks like i'm back in the game thanks to my brother. he went and bought an'02 bird, and since i'm a technician at the nissan place guess who gets to work on it
    2013 Ram 1500 Big Horn
    94 comero 3.4
    Nice, welcome back. Any plans for it?
      it currently has jegs rims & off brand tires, switching those out for stock to help ride, which is rough. has a leak at one of the power steering lines & hslow steering. gonna replace pump/reservoir and investigate a possible rear main leak once he gets tags for it. gonna bring into work & put on lift for better inspection. when i did crawl under at house he bought itfrom harsly any rust and iirc 129k miles
      94 comero 3.4
        Welcome back. I still remember your build of putting a 3800 in a white 3rd gen firebird.
          Nice.
            it wasn't white, it was frost beige ...... like a pissed on to faded yellow
            too bad they trashed cardomain, lotsa good info lost
            94 comero 3.4
              been a while but here's the latest:
              changed shocks all around, front left was decent, front right was a pain for some reason..... took a lil but the front lift finally settled in.
              changes the tensioner assembly
              dealing with issues on the driver low beam.... already replaced the connector & pig tail but need to inspect some more (got pig tail for other side just in case).
              the front turn signal connectors are fried also, replaced the pass side , driver side i jb welded and gonna replace if that acts up again.
              interesting that rear spinga dont have lower isolaters, unless they just deteriorated away.
              94 comero 3.4
                Yeah the fronts can be a pain sometimes, up top I switched the hex bolts to regular bolt heads, best thing for the front shocks. Yeah the rear shocks are better with the isolators more smooth. What shocks did you go with?
                  kyb excel g all around. i put those in my truck and was happy with.
                  also fixed the connector to the driver low beam by removing the connector and using red spade connector things onto the bulb prongs. it actually fit tighter and no scorching the prongs from bad connection
                  94 comero 3.4
