PC Help - FirebirdV6.com/CamaroV6.com Message Board
PC Help
  • PC Help
    At the moment at the house i only have 1 pc and it just so happens im stuck with the one that cant browse websites. This sucks what good is a pc if you cant search things?
    I have a dsl connection and on the little icon next to the clock it says "limited or no connectivity" so i hit the repair button and it says that it failed to renew the IP address.
    SO i think hmm ok ill just manually do it so i open up the command promt and release all the IP's and i try to get new ones but it gives me an error something like it failed and was unable to give me an IP addy.
    It will give me a subnet mask but no ip or default gateway.
    When i DO try to browse a site it says page can not be displayed, i was thinking it has something to do with the DNS?
    Any help is appreciated.
    So you're computer is connected directly to your DSL modem? How long have you had this problem? Have you called your ISP to see if its a problem on their end?
    ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
      well its been like that for like 3 months but like i said that computer is hardly if ever used to browse the net so i never cared, but now im stuck with it for a while.
      IVe called the isp,gateway because they made the comp, i even called the ppl that made the network card on it and no one could help me.
        run repair thru the dsl modem software. I have the 2wire dsl modem & it has it's own firewall & troubleshooting software.
        2013 Ram 1500 Big Horn
        94 comero 3.4
          I uninstalled the DSL software BC i taught this was the problem and when i try to reinstall it says modem not found. so im
            2wire is not good because since it is a router/modem combo it is really hard to repair if one part breaks. i would bersonally stay away from it. plus all my coworkers told me the same thing (i work at a pc tech shop)
              the modem i have is a speedstream
                I haven't had any probs w/teh 2Wire, plus since I don't thow it against the wall, it doesn't brake.
                94 comero 3.4
                  have you unplugged the modem and replugged it in??
                    sorry unplug and replug the power for the modem
                      YES,
                      i have a feeling it has to do with a file or something in the windows system.
