What makes the speedo read lower than it is actually going, bigger or smaller tires and bigger or smalle gear ratio????
Speedo ?
Higher gears (numerically lower) than what the PCM is programmed for will result in driving faster than what the speedo shows.
I believe larger diameter tires have the same effect.Matt
1998 Mystic Teal Camaro M5
so like 2.73s u would be goin faster than the speedo shows than if u had 3.08s?1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
Originally posted by Everglades W68:
I don't wear a Speedo to the beach anymore - it caused a massive crowd of ladies throwing themselves at me.
Stock gear / new gear * Speedo = Actual speedMatt
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...9 hours ago
