Calling all high mileage cars!!! - FirebirdV6.com/CamaroV6.com Message Board
  • Calling all high mileage cars!!!
    I'm on a quest to find other high mileage f-body owners. Chime in and prove that Hondas and Toyotas aren't the only cars out there that can run forever, except ours do it while making real power. [img]graemlins/burnout.gif[/img] Also take a moment to brag about any engine mods that have stood the test of time.
    I've got a little over 202,000 miles right now on a pretty stock engine. In that time I've gone through a transmission, driveshaft, radiator, water pump, heater core, 3 alternators, 2 tensioner pullies, tie-rod ends, and a set of rear bearings. The engine is still strong as ever, though. [img]graemlins/naughty.gif[/img]
    How about you guys?
    1997 Camaro, Y87 Perf. Package, iRotor Drilled & Slotted Brakes, Bilstien Shocks, Custom drive shaft, K&N Filter, & Mobil 1 synthetic. 202+K miles and still drives like new.<br />-If you can\'t stomp \'em in the straights, kill \'em in the corners...
    Little over 150,000 miles here
    Transmission, waterpump, and tensioner pully have been replaced
    My A/C doesn't work now, though :(
    ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
      How about you guys?
      haha, I got the high mileage for my year
      2002 with 101,400
      so in 3 more years I should be nicely catching up to you lol
      millionformarriage.org
      Why stop people from getting married?
        Almost 160,000.
        I wish I knew what all had been replaced I bought it used about a year ago.
        \'96 A4 Camaro 3800<br />Nothing but... <br />Flowmaster 40 series
          172,000. I've had it for a year and had to replace just the alternator and fuel pump.
          1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
            Almost 129,500 miles
            *~* Tasha *~*<br /><br />\'96 Pontiac Firebird, 3.8L, 5 speed<br />\'91 Chevy Z28, 305, 5 speed - SOLD<br />\'73 Plymonth Duster Twister, 318, automatic<br /><br /> <a href=\"http://www.cardomain.com/id/domesticchic\" target=\"_blank\">http://www.cardomain.com/id/domesticchic</a>
              My car is just a youngster...93,000+ miles.
              It's a 1995 with a 3.8 V6 bought with 42,000 miles in 1998. The only parts replaced: Battery, brakes, plug wires and a noisy headlight motor.
              It's only a occasional driver, but still runs like a champ! [img]smile.gif[/img]
              Stephen<br />1995 Pontiac Firebird<br />3800 Series II V6<br /><br />2000 Pontiac Firebird Formula
                how much does it cost to replace that "noisy headlight motor" its driving me nuts! I pull up into my parking space in school in the morning and have a few ppl checking my bird out and then that awful noise... and i get funny looks. I hate that noise!
                1994 Pontiac Firebird M5<br />Flowmaster 80 Series/dual pipes<br />Magnaflow High Flow Cat<br />eBay two piece intake<br /> <a href=\"http://www.cardomain.com/ride/2112560\" target=\"_blank\">http://www.cardomain.com/ride/2112560</a>
                  160,000+ miles here. Don't even ask what I've had to replace lol.
                  Engine mods? Turbo? [img]smile.gif[/img]
                  -Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
                    183,000 miles
                    the black 97 <br /> New favorite Mods: Hptuners, and SLP 2OTL
                      Just a little over...
                      http://home.rochester.rr.com/earnhar...7777%20001.jpg
                      <b><i>Don\'t Ever Judge Me</i></b><br /><a href=\"http://www.cardomain.com/id/earnhardt132000\" target=\"_blank\">\'96 Firebird Y87 3.8L V6 5spd</a><br />--No mods as of yet, shoot me some ideas if ya want.<br />178,000 miles and counting
                        That's pretty freakin' cool. [img]graemlins/rock.gif[/img]
                        (I thought I was the only person who did odometer pictures.) ;)
                          160K miles, Tranny, Polyurthane Tranny Mount Driveshaft, Suspension Components, Water Pump, Radio, Driverside Door, Headliner, Entire Front End are the major things that I've replaced or am going to replace so far...
                          Brakes/Rotors, Tires, 3.5K Interval Oil Changes, Full Plugs/Wires Tuneup, Fuel Filter, PCV Valve, O2 Sensors, EGR Valve, Radiator Flush, Rear End Fluid Change twice now...
                            around 135000,still pulls like new :D
                              147,000 miles
                              new water pump, timing chain and gear (replaced with water pump as a precaution)
                              needs a valve job...valve stem seals leak oil down..burns it off on startup...
                              2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
