Torque management? - FirebirdV6.com/CamaroV6.com Message Board
Torque management?
  • Torque management?
    Can someone give me a brief definition of what torque managment is and how it affects your car?
    1996 Camaro -- SLP CAI, Motorvator TB spacer, MSD 8.5 mm wires, 180 thermostat, Pacesetter headers, Catco 3 in cat, TSP Rumbler, custom painted interior, 18x9.5 Z06 replica wheels, Nexen N3000 265/35r18 tires, - Best 1/4 mile 15.3@89mph
    Torque management = right foot
    -Justin
    <b><a href=\"http://www.cardomain.com/id/drkmind11\" target=\"_blank\">2000 Red Firebird Coupe, A4.</a></b> ((3.42 Gears, LSD Stock))<br />Details: 3\" Edelbrock Exhaust, 3\" Catco Cat,160* Thermostat, 8% Tint, TA Chrome Wheels, Viper 550.
      Justin Kirkham
      Member # 1992 posted July 27, 2004 04:40 PM
      -Justin
      [img]graemlins/rofl.gif[/img]
      <b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six</a> </b><br /><br />1998 Sport Metallic Gold Firebird A4:<br /><br />Whisper Lid, 5% Limo Tint, 30th Anniversary Side Stripes, 3\" Borla Catback Dual Exhaust, Man Fan Switch, SLP CAI<br /> <a href=\"http://members.cardomain.com/98goldbird\" target=\"_blank\">http://members.cardomain.com/98goldbird</a>
        you want a nice high, flat torque curve. haveing a peaky curve means you have to shift a lot to get any power out of the car. hope this helps
        UAH FSAE<br />Chief Engineer<br /> <a href=\"http://chargermotorsports.com\" target=\"_blank\">http://chargermotorsports.com</a> <br /> <a href=\"http://members.cardomain.com/camaronat\" target=\"_blank\">http://members.cardomain.com/camaronat</a>
          wtf does that have to do with a automatic transmissions's torque management? It controls the amount of torque going to the wheels to keep it smooth and stable, ie wheels aren't slipping. (not good for performance minded driving)
          00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
            I am sure he will enjoy this worthless information.
            Torque management is used on newer cars with automatic transmissions. During the shift the computer will decrease power so there is not a big shock to the drivetrain when the next gear engages.
            This can be a problem if you install a shift kit. It doesn't render the shift kit worthless but probably decreases its effectiveness. Custom PCM tuning can get rid of torque management. Although according to Wester's (as in Wester's Custom PCM tuning) you shouldn't get rid of all of it as that is unsafe (not sure if he means unsafe to drive or unsafe to the well-being of your drivetrain).
            Here is a link for you. Read the last question in the FAQ:
            http://www.kdsperformance.com/faq.html
            SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
              Torque management is over-rated. It's yanked off my car. [img]smile.gif[/img]
              If something breaks, get a better non-stock item.
              Removing it will definately wake up the car, however, you shouldn't be getting on the car 24/7.
              2002 NBM Firehawk #312 | <a href=\"http://hawk.visionsconnect.com\" target=\"_blank\">hawk.visionsconnect.com</a>
                in particular during shifts the pcm retards engine timing several degrees for a short period.
                  Is that why my friends 2000 3.8 auto mustang can get second and my car doesnt even jerk when it hit second?
                  1994 Arctic White Camaro T-Tops(all options except leather)<br />80 Series Flowmaster Muffler<br />Ebay Cold Air Intake<br />Earthquake in the back known as a Kicker Solo Baric 15 L7<br /><br /> <a href=\"http://www.cardomain.com/id/sirshaun\" target=\"_blank\">http://www.cardomain.com/id/sirshaun</a>
                    never heard of torque managment.
                    1995 Patriot Red T-Topped Z28 A4<br /><br />Mystery rebuild in progress.<br /><br />Soon to have 383 ways to beat KBreezy and Shane. :D
                      im pretty sure its not a GM thing.
                      2000 3.8 A4 Pewter Camaro
                        So basically when people talk about removing the Torque Management when installing a shift kit, it means to remove the decrease in torque that automatic transmissions have during shifts? this way continuous power will go to the tires (which is what we want) without causing a stall in case of chirping the tires? am i right?
                        What are the options out there to remove the torque management?
                        2002 Arctic White Firebird W68<br />Installed: FTRA, Carbon Fiber Whisper Lid, K&N Filter, Transgo Shift Kit, Corvette Servo, 160º Thermostat.<br />Appearance: Potenzas RE750 245\'s, 3M Tint 20% All Around, Clear Corners.<br />FOR SALE: HPP3
                          Torque Management same as traction control?
                            no but its works with the traction control to retard the timeing witch puts lees power to the ground so the rear tires can catch a grip. traction control applys the brakes a little bit to help slow the tire. this ties in with the ABS system do do this.
                            www.turbov6camaro.com
                            1997 3800 Series II Camaro
                              Yeah, it is. If you have a 99+ Camaro (not sure about previous years) you have torque management.
                              The options to remove it are HP Tuners Software, Westers Custom PCM Tuning, or Texas Speed Custom PCM Tuning (they use HP tuners software).
                              I have Westers and my 1-2 shift is very firm and fast. Whips the head back a little bit.
                              Where have you been? [img]smile.gif[/img]
