ZAINO WAS MAKING ME MAD - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    WTF? I know there are better products out there compared to zaino. It is not the end all to everything. But what lasts as long and looks as good? Whats as durable? Whats it cost?Give me specific products, not just list oh... poorboys, klasse, wolfgang etc... What do you use?
    If I said I use zymol, I coudl be using the $9.99 blue bottle from autozone, or I could be using the $1,350 for one jar stuff they sell, or just one of their $200 detailing kits.
    My thoughts about average cleaner wax you get at autozone. Think about appearance mods you get at autozone, neon shifters, crappy decals, type R badges, seat covers that don't fit right. Think about performance exhaust you get there, fartcans, 40 series flomaster, $15 thrush mufflers, screw on tips that don't fit right clamps and flexpipes.
    Originally posted by hawgs
    A black car that's been prepped (and no wax or ANYTHING applied to it) will look 10x better than an unprepped car with 500 coats of zaino (and thats a whole other can of worms, anyone who believes their coats of Zaino or any other product are actually adding up is out of their mind, after about 5-6 coats you've reached the max "depth" of coverage you're ever going to get).
    And Hawgs,(I know you will fight kick and scream like a little girl about this) but you are wrong.
    A black car prepped and not waxed will look better then a carnuba waxed car you are right. BUT ZAINO IS NOT A CARNUBA WAX! THAT IS WHY PEOPLE LIKE IT!
    What wax in the world do you know is 100% clear? none, all have a dulling haze look to them.
    points about Zaino.(I bolded some main points)
    http://www.ls1camaro.net/sections.ph...rticle&artid=7
    About typical carnuba waxes
    "Zaino contains no wax (unlike Meguiars 3-step and all other non-synthetic
    products)
    . Wax has little durability. Carnauba is a hard, yellow, brittle
    wax no matter what they try to tell you. It must be softened with solvents.
    It its FAR from optically pure. It melts at low temps easily obtained on
    darker cars. Why do you think you can't apply it in the sun? Such waxes are
    always mixed with other cheap waxes like paraffin (candle wax). Paraffin melts
    around 135F. The product is no stronger than its weakest link. Zaino can
    withstand temps well over 300F. "
    Thats the main thing when you compare a shine of a car over others. Zaino is not a wax, and is waaaaay more optically pure.
    "It shines from the paint surface itself, not from the oily surface as
    all waxes do. This allows paint to show off its original color and allows
    metallic and "mystic" paint to look more effective"
    And you say zaino is "fake looking" one. When you use other waxes you are shining off the oils on the surface of your car more so then the actual paint. Go rub cooking oil on anything and it will look "glossy" but you lose some of the properties of the paint by doing this.
    "Zaino contains no abrasives. Most wax products contains abrasives even when
    they say it doesn't on the bottle. If you have a single stage paint and you see
    the color of your car on your applicator, you can bet there are abrasives in
    your product. I would rather leave abrasive products to the professional glazing
    industry like 3M or Presta. You can't get consistent abrasives in a departments
    store shelf products. They will invariably leave scratches. EVER WONDER WEHRE
    THOSE SWIRLS CAME FROM??? You wash your car and go through a couple of rains or
    lots of sun and ask yourself, "where did those from? I was so careful when I
    washed..." It's often from the cheap abrasives (like SAND) in the wax itself and
    since the oils have rinsed off, you can now see them.
    People still don't get it. Wax is not healthy for your paint. People however don't listen, so those that use it will have to suffer the consequences in the long run. Ever see a finished that has been waxed religiously over the course of many years? The paint gets pretty thin. Why? Wax is abrasive, wax is a crystaline structure that needs solvents to be spread thinly, wax literally wears down the paint. It looks good while waxed, but that is like giving a decongestant to someone with a cold and claiming they are cured. It doesn't matter how the shine is perceived or acheived, it is destructive to the finish in the long run.
    More info about the defects of using carnuba waxes
    http://www.ls1camaro.net/sections.ph...rticle&artid=6
    "The truth of the matter is Carnauba is a dark yellow, brittle wax. It
    has no durability. It also has no high shine. In reality it's actually a
    dull wax. It is not optically perfect and leaves a film (haze) on the
    paint finish. If you took two identical colored cars and placed them
    side by side. The one with Zaino would be the true color. The other car
    would have a slightly different tint to it.
    What you are seeing with Carnauba is a combination of carnauba wax,
    polyethylene wax, paraffin wax and the key gloss ingredient SILICONE
    OIL.
    Silicone oil is inexpensive, greasy, smeary, not durable, but shines
    like crazy. Just try Pledge furniture polish on your car. Voila same
    shine. Hmm. Pledge is loaded with silicone oil, so is Armor All tire
    dressing. Did you ever notice how greasy, smeary and dusty, furniture
    looks with Pledge on it. How soon does your car get dusty after you
    polish/wax with your favorite product????? When does the gloss start to drop???
    I already know. Now here's the best part. Silicone oil and other oils are an essential
    ingredient of Carnauba based products. It's the only way to achieve a
    shine. That's why it's used in all Carnauba based polish/wax. However,
    it has no durability, does not last and it attracts dust and dirt like a
    magnet and once dust settles on it, it sticks to it. Dust on paint
    causes tiny Swirls and Scratches. Also Carnauba is very brittle. It will
    not stay on the paint surface for any length of time. Most of the time
    less than 3 weeks....... The sun also effects Carnauba based products.
    The sunnier and hotter it gets, the faster it deteriorates. Remember wax
    melts and oils tend to migrate to the surface and evaporate... Sad but
    true.
    Fact: On a sunny 80 degree day, the surface temperature of black paint
    will reach 149 degrees and go up to 198 degrees if the ambient temp
    reaches 90. It doesn't take a rocket scientist to figure out what
    happens to the wax.
    When designing and formulating a polish. These are just a few of the
    factors that you want to avoid.
    Show Car polish has a wet looking gloss, incredible durability, water
    beads like crazy, is not effected by the sun and does not attract dust
    or dirt. There are no oils, abrasives or wax in Zaino. Nothing sticks
    to Zaino Show Car polish.
    • #17
      How dare you play the "I am in the military protecting you and fighting for you so don't say anything bad to me" card... thats so lame. Do not take that as me being ungreatful for your services, but do not hold it against me that you choose to go into the military.
      With that being said... I think you, Viper, could really benefit from reading some threads from www.autopia.com ...those guys really know their stuff when it comes to this. There is so much to learn and you can see what works on other peoples cars and trying it on yours. That site is not good for closed minded people who think that one product reigns supreme over all others... so you will need to change that before checking it out.
      • #18
        By not joining the military I'm giving illiterate people a chance at doing something to benefit this country ;)
        • #19
          I agree that its a good board, but just like Zaino zeolots, there is just plain zaino bashers.
          And as for the term Zaino Zealots. What car polish has even as close of a following? I have never heard of NXT LOVERS or WOLFGANG WOOHOOERS!
          Mayeb there is a reason so many people enjoy zaino?
          and Hawgs HAVE YOU EVER USED ZAINO!?!?
          I love the fact that everyboard I go on, peopl jsut go into zaino threads and say its crap, use this. But most never used them or never used it right.
          and another question... WHY THE F*CK DO PEOPLE GO INTO ZAINO THREADS JUST TO B|THC ABOUT IT! honestly do I go into threads about pioneer amplifiers and B|TCH that you could get an nice MTX amp, they are better? No because I have no clue, never used either one. Don't really even care about them since I don't use either amp. So Why the feck should I go into these threads and B|TCH. It woudl be just plain retarded.
          [ July 28, 2004, 06:36 PM: Message edited by: MustangEater8251 ]
          • #20
            Btw hawgs...
            in 3 different threads you have still not answered my question.
            To me it jsut looks like you did a quick skim/search of autopia.com and just spouted some crap like you knwo what your are talking about. Just to be a prick(as usual) on the boards.
            You have had like 2 days to research and make up some answers by know think you would have posted.
            I am willing to try different stuff and research it. But these questions were not answered.
            • #21
              actually Eric... I don't think you know as much about waxes as you'd like to think. Are you fully reading all of my posts fully? I know they are a litle longer then the "How To" instructions on the mop you use at work everyday but just try and read a couple all the way through... I will try and go slow and keep it simple for you.
              I haven't said anything bad about Zaino. I just feel that people should have options. Without options, it just promotes ignorance, which is far too common on car forums. Your car looks nice, but lacks depth of color, which many people like. Some people like the saran wrap look and Zaino will give you that. Any person who is honest to themselves will tell that's what Zaino gives you.
              This whole Zaino cures cancer mentality drives me crazy. I'm just trying to help with my knowledge, experience, and resources.
              Check out www.autopia.com and see whats right for you Eric. You will see that just because you put Zanio on your car doesnt mean it is the best it will ever look. Give other things a try... get a PC buffer and a couple polishes and see how they work for you. Don't just limit yourself to Zanio because someone said it was good.
              • #22
                I will answer your questions when I get home... I am leaving for the day, and off to the my suite for the Astro's game tonight... I will be back, never fear. [img]smile.gif[/img]
                A quick answer is I've used a porter-cable dual-action polisher with Wolfgang and I've used it with Menzerna polishes on my 69... like I've said in another thread.
                • #23
                  *sigh* I wish it would not rain this weekend, my car hasnt been Zainoed in a few months now. [img]smile.gif[/img] I really do like Zaino but I think i am going to try some of that NXT next time. I live in NJ so Zaino is hard to get.
                  <a href=\"http://www.cardomain.com/id/maleet\" target=\"_blank\">1998 Silver Firebird</a> <br />Basic mods... nothing real special but it sure looks good!<br /><a href=\"http://www.maleetpobanz.com\" target=\"_blank\">maleetpobanz.com</a>
                  • #24
                    [img]graemlins/popcorn.gif[/img]
                    [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img]
                    The bastardification of Third & Fourth gen cars.
                    • #25
                      So wow... instead of of getting in depth... you try and make up a personal attack by saying I am a Janitor(still not understanding where you get that from in Chat) And talking about a suite at an astros game... trying to inflate your ego that you are better then others. yet again... [img]graemlins/rofl.gif[/img]
                      I never said I was the expert. You are the one proclaiming to be an "expert" of knowing whats the best product for MY CAR. I am just simply stating facts about zaino and carnuba waxes. YOu tell me other stuff is better. I ask WHAT IS BETTER, you just list off some brand names, doesn't help me. You are the one pretending to know everything and tell me what is better for my car, over a thousand miles, 5 different states away. If you asked me for a description of what Zaino products to use, I woudl give you a list. Do I think zaino products are the only products you should use on a car nope. I'd use 3m swirl remover with a buffer for deep swirls/scatches. But "light" swirl I say use Z5, and for topcoating I reccomend Z2. Z7 is just a good carwash and costs like $7 for a bottle of concentrate, works great and doesn't contain as many harsh detergents on your car, so figure might as well snag it with the rest of a zaino order. Z6, even people that dog zaino, use this with there other products because its a decent detailing spray.
                      As for Z18, its 2 good laybars, you could go buy 2 good ones at a car store, does the same thing, but will cost the same, why not just order it and get it with the rest of your stuff(one stop shopping)
                      As for interior stuff, I hear lots of people like the glass cleaner, but I havent used, I use a lense cleaner to clean my glass(if you do this make sure its safe for tint) I haven't heard anything special about dash and trim cleaners or the tire shine, but nothing really "bad" about them either.
                      You buy the starter kit, and bam you have everything thing you need but a bucket, hose, and some towels to detail your car.
                      I provided links and made my points. You say ZAINO IS NOT GOOD, GO TO AUTOTOPIA.COM!
                      So once again you list a brand name not the specific products, but you gave me a half good description about your buffer?
                      And before you try to put works in my mouth again. :rolleyes: "I DO NOT THINK I AM AN EXPERT IN DETAILING CARS!"
                      YOu seem to be the expert just asking advice...
                      In fact I don't think I am an expert in anything, anyone who does is likely a concede prick full of themself.
                      • #26
                        1st i hate reading lol
                        but really i wasn't hiding behind my militray status, i was just trying to get you to wake up and relize that you DO NOT HAVE TO COM IN THIS THREAD and bash me i never said it WAS THE BEST IN THE WORLD, i siad IT WAS THE BEST I HAVE USED. lol hawgs i really dont car what you call cuase there no way it gonna top what TI told me called me in basic. lol [img]tongue.gif[/img]
                        this is why i dont like this board all i tried to do was post about a prduct i bought and was VARY HAPPY with and all i get is crap from a few members.
                        www.turbov6camaro.com
                        1997 3800 Series II Camaro
                        • #27
                          THANK GOD! I thought I was taking crazy pills or something. I only have this problem on this BOARD!
                          Once again, like I said, if I hated Pioneer amps, woudl I go into every thread about pioneer amps and say they suck, especially when I have never even had one?
                          • #28
                            yeah that's why they give us guns to shot the trash that stup as low as you just did.
                            but wait the little winky eye is expose to make it ok........
                            im sorry man that was really low and that hurts, theres not alot that bothers me but that does
                            in school i was NEVER good at spelling i would study all week my mother would give me tests and i would do fine but buy the next moring for the i would forget i don't know why..... i'm slow in that area i gusee :( same with grammar i sucked still do
                            now weather, vocaneos, electronics and such i'm REALLY GOOD AT.
                            • #29
                              you forgot that you're also good at putting together 12 pages of mods to your car ;)
                              • #30
                                </font><blockquote>quote:</font><hr />Originally posted by ReodDai:
                                </font>[/QUOTE]BTW I think ReodDai is trying to become the next piece of firebirdv6.com sh|t. They should start a club...
