^^^^ (Mogobs) that makes too much sense and therefore must be wrong.
A question...
This topic is closed.
Originally posted by asdf1234:
</font><blockquote>quote:</font><hr />Originally posted by airfrmr:
I don't know about Matt, but that scares the **** out of me.
It shouldn't. I understand what he is getting at. Just not how an airplane sitting on a stationary treadmill is still moving forward, and I'm sure I'm not the only one.
Hopefully my last post makes some sense of it. </font>[/QUOTE]you always hear of plane crashes because of mechanics and maintanance failure
Originally posted by Mogobs30th:
</font><blockquote>quote:</font><hr />As the plane moves the treadmill moves but in the opposite direction. The treadmill has a system that tracks the speed of the plane and matches it exactly in the opposite direction
In order for the plane to take off, it must outrun the speed of the treadmill THROUGH the wheels. But it cannot because the planes speed is being counteracted by the treadmill THROUGH the wheels, regardless how fast the wheels are spinning. </font>[/QUOTE]Mogobs30th agrees with me. This conversation is OVER!
Originally posted by BLLDOGG:
</font><blockquote>quote:</font><hr />Originally posted by asdf1234:
Hopefully my last post makes some sense of it. </font>[/QUOTE]you always hear of plane crashes because of mechanics and maintanance failure </font>[/QUOTE]Excellent point. Okay so I'm still scared.-Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
No, I'm not designing, just fixing. I understand the whole thing about how an airplane works...it is either pushed or pulled through the air and that, depending on the plane, may need to travel roughly 100 mph or more to have enough wind speed to create lift on the wings. Which tells my uneducated mind that it will not move forward or gain flight on a treadmill.
Ok, so you tell me...
The engine is making, say 1,000 lbs of thrust. How is the treadmill causing 1,000 lbs of drag on the airplane? The forces must be equal for the plane to stay still.Matt
1998 Mystic Teal Camaro M5
if the tread mill is the runway...then how long is the runway?FOR SALE: 94 3.4 camaro <a href=\"http://www.cardomain.com/ride/2193648clutch240@yahoo.com\" target=\"_blank\">http://www.cardomain.com/ride/2193648clutch240@yahoo.com</a><br />my import with a touch of american muscle..... <a href=\"http://www.cardomain.com/ride/2090657\" target=\"_blank\">http://www.cardomain.com/ride/2090657</a> <br />\" Im getting a foot-print gas peddle installed, so i stole this pile.\"
The treadmill has a system that tracks the speed of the plane and matches it exactly in the opposite direction.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
Originally posted by 3.4 slow to go:
it is because it states it in the question.Matt
</font><blockquote>quote:</font><hr />Originally posted by 98Camaro3.8:
The treadmill has a system that tracks the speed of the plane and matches it exactly in the opposite direction. </font>[/QUOTE]It matches the planes speed, not the wheels speed, and even matching the wheels speed wouldn't be relevant.
Say the plane is moving forward at 10mph, then the treadmill would be moving backwards at 10mph, but the wheels would be traveling at 20mph. Therefor the plane would still be moving 10mph forward, and the backwards motion of the treadmill has nothing to do with it.-Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
wtf are you talking about? the plane is just going to sit there w/it's wheels spinning, no matter how much thrust is used, as the treadmill will go that much faster to keep the wheels in place1978 Formula 461 in progress of being built :rock:
94 comero 3.4
aircraft engine= 1000lbs of thrust
tread mill= 900mph
we're still not going any where...FOR SALE: 94 3.4 camaro <a href=\"http://www.cardomain.com/ride/2193648clutch240@yahoo.com\" target=\"_blank\">http://www.cardomain.com/ride/2193648clutch240@yahoo.com</a><br />my import with a touch of american muscle..... <a href=\"http://www.cardomain.com/ride/2090657\" target=\"_blank\">http://www.cardomain.com/ride/2090657</a> <br />\" Im getting a foot-print gas peddle installed, so i stole this pile.\"
wtf are you talking about? the plane is just going to sit there w/it's wheels spinning, no matter how much thrust is used, as the treadmill will go that much faster to keep the wheels in place-Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
well, until the plane is air born, the plane needs the wheel for movement. so if the plane moves forward 1mph, the treadmill is moving backwards instantaniously 1mph which would cuase no movement.
