How come front wheel drive transmissions are so much more fragile then rear wheel drive, I used to have a 2000 saturn with a 5 speed and 30k miles and I trashed not one, but 2 transmissions! Now I'm in my camaro with 155,000 mi. and the bullet proof 4l60e still runs strong despite a very abusive previous owner. It's not just the saturn, but my friends ford escort GT (manual) then again on his 98 nissan altima (replacement for the ford) and my other friends neon (auto) all trashed their trannies too. Each and every time the differential pin punched a hole through the tranny case. When I complained, the saturn mechanic said that durning wither he see's alot of cars come in with the same thing because the wheels will slip on ice and then abruptly gain traction resulting in a blown tranny. I just can't comprehend how fraile these are, a worn syncro, or a gear faliure on a boosted car I can understand, but this was absolutly ridiculous! Any mechanics or engineers out there know what is behind this?
Fragile FWD's
The 4L60E is also used by the V8, I don't know if there's any internal difference between the V6 and V8 transmissions, but, if not, that's why your trans is "bulletproof". It's designed for a lot more power. Autos also take a lot less abuse than manuals because it's much harder to shock them with an abrupt load.
It's pretty much a car specific thing, not "FWD". I autocrossed and roadraced (Showroom Stock) a VW Scirocco for 4 years with no transmission problems.2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
Yeah I love our indestructable drivetrains... ohh wait... :(-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
V6Bob touched on it. Our 4L60E's were designed for big, torquey V8 engines. Our little v6's barely stress them, so they are pretty bullet proof in our cars (although I am on my second). On the other hand, V8 tuners always point to out stock 4L60E's as a likely point of failure because they run so much more torque than we do. That's usually one of the components they go out of their way to beef up before doing any major mods.
The transverse mounted transmissions in most cars are really trans-axles containing the transmision, the diff, and all the gearing needed to rotate the engines rotational energy 90 degrees to the wheels. They have to put a lot of stuff in a very small amount of space, so they tend to be built just strong enough to get by with the required amount of reliability. Most consumers do not hop up their engines, so it is not cost effective for most companies to build these units any stronger than the average consumer requires. For example, the reason GM only boosted the S/C 3800 SII engines to 240 hp was not because of engine any limits. (They can actually produce over 300 with just moderate boost.) The stock tranny's for the FWD cars just couldn't handle any more torque withough killing their reliability and it wasn't cost effective for GM to build a new, stronger transmission just for these cars.
You are starting to see more FWD cars makng big Hp now, and these cars have much beefier trannies.1997 Camaro, Y87 Perf. Package, iRotor Drilled & Slotted Brakes, Bilstien Shocks, Custom drive shaft, K&N Filter, & Mobil 1 synthetic. 202+K miles and still drives like new.<br />-If you can\'t stomp \'em in the straights, kill \'em in the corners...
It's pretty much a car specific thing, not "FWD". I autocrossed and roadraced (Showroom Stock) a VW Scirocco for 4 years with no transmission problems.<a href=\"http://www.cardomain.com/id/vracer111\" target=\"_blank\">My \'98 Camaro</a><br /><br /><a href=\"http://www.honda-tech.com/garage?cmd=viewcar&id=1223\" target=\"_blank\">My \'98 Tacoma</a>
