Windows XP *EDIT* RESOLVED !!!! - FirebirdV6.com/CamaroV6.com Message Board
  • Windows XP *EDIT* RESOLVED !!!!
    Can anyone post the directories which the following file can be found - lsass.exe
    Or if possible can you mail me a copy of that file from your windows\system32 folder?
    - NM, got 2 copies now!
    I'm running into a great problem:
    Basically the lsass file in my windows\system32 folder has become corrupt (computer was either restarted during the middle of a patch "push-out" by IT, or the HD has a bad sector - yea!). This means that my computer reboots, displays a lsass.exe "When trying to update a password, this return status indicates that the value provided as the current password is not correct." and then reboots again.
    It's a known microsoft issue, and their response "it will be fixed in the next service pack, reimage your computer sucka!".
    Reimaging is not an option at the moment (there's a couple of important files that have not been backed up in 3 weeks or so). I've managed to get everything else under control (system files/emptying my admin password - great utility to do that found at http://home.eunet.no/~pnordahl/ntpasswd/
    This is the last step before kicking the laptop.
    [ September 01, 2004, 10:57 PM: Message edited by: C.O.Jones ]
    <a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six</a> <br /><b><a href=\"http://www.cardomain.com/id/c_o_jones\" target=\"_blank\">Cardomain</a></b><br />--This doesn\'t change the fact that I am ~The Guru~ who still kicks puppies...
    You got mail.
      Sorry, had to change the e-mail as I just learned, Microsoft in their infinite wisdom permanently blocks that file. Well isn't that special.
        Still need it Rob?
        <b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six©</b></a><br /><a href=\"http://www.sounddomain.com/id/95batmobile\" target=\"_blank\">My \'95 Bird</a><br />I am not afraid of storms, for I am learning how to sail my ship.
          did you ever try the search button? Seems to be a problem here. [img]smile.gif[/img]
          <b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six</a> </b><br /><br />1998 Sport Metallic Gold Firebird A4:<br /><br />Whisper Lid, 5% Limo Tint, 30th Anniversary Side Stripes, 3\" Borla Catback Dual Exhaust, Man Fan Switch, SLP CAI<br /> <a href=\"http://members.cardomain.com/98goldbird\" target=\"_blank\">http://members.cardomain.com/98goldbird</a>
            Yep, still need, or even the locations (Will attempt to copy from other location on hard drive if possible).
            did you ever try the search button? [Confused] Seems to be a problem here. [Smile]
            I don't get it. I've spent about 7hrs going through google, on the phone with Dell, and troubleshooting it myself to get to this point.
              sent the .exe to you and also rar'd it for you incase of virus prevention sh*t.
              If you need anymore help let me know..
                Hey thanks!
                A friend sent me one also. They're both the same size with the same datestamp. Here goes nothing...
                  good luck...
                  If you need more **** I'll try to check the board frequently enough to help you [img]smile.gif[/img]
                    RESOLVED!
                    2 years ago a friend of mine gave me a disk labeled "XP OEM Boot Disk" This disk saved my life. Since I was using a laptop (for work) I had no way to remove this HDD and plase it as a slave in another computer.
                    This damned boot disk appears to preload windows and run it from the CD! Once loaded it gives the user a command prompt. The best part: It recognizes USB!!! I was able to get to the DOS prompt and move all my importand data via USB keys to a computer and burn that info to CD. Without this disk I would have had to shell out MAJOR $$$, buy a 2nd hard drive and a drive caddy...
                    Tomorrow I'll make a .nfo file. Anyone want it/have a place to host it temporarily. This could save your a$$ one day.
                      I have a CD like that [img]smile.gif[/img]
                      When my HD died I was using it so I wasn't without a computer....... it wasn't really a boot disk though, it was actually windows running on CD.
                        Originally posted by C.O.Jones:
                        RESOLVED!
                        i can host it
                        www.turbov6camaro.com
                        1997 3800 Series II Camaro
