GMPartsDirect - FirebirdV6.com/CamaroV6.com Message Board
GMPartsDirect
  • GMPartsDirect
    Cliff notes: GMPartsDirect sucks ***! :mad:
    Full Story:
    This is the 2nd time I've tried ordered from GMPartsDirect, but it will be the last. The first time went smoothly, although slowly. This time is rediculous. I'm trying to order the final few gaskets I need for my heads/cam swap.
    To start off with, I wanted to get some new lifters. I figured it would be cheaper to just get stock OEM lifters, rather than going with Comp Cams. Comp Cams OE lifters were $160 on Summit, so I figured I could get OEM ones cheaper...wrong! I go to GMPartsDirect, enter the part number, and see a pack of 8 for $22.84. It's a pack of 8, so I'll have to get 2 of them for $44, with a few left over...no big deal, right? I add 2 packs to me cart, check the price, and see a total of $438.53, including $73.09 for shipping! WTF?!?! $365 for 16 lifters, when I can get them from Comp Cams for $160? And $73 in shipping for something that weighs no more than a pound??? Summit charges 8 bucks for S&H. Can someone explain why the hell I would pay almost $450 for lifters, when I can get better ones for $170 shipped? Note: It says I would have saved $365 by ordering from them. For some reason I find it hard to believe that GM would charge $750 for a pack of lifters.
    OK, so I went ahead and bought Comp OEs from Summit, and decided to get the rest of the parts I needed from GMPartsDirect. I had $100 worth of gaskets (including a new fuel pressure regulator and lower intake gasket kit) in the cart. Go through checkout, and it says my order has failed, because the zip code was incorrect. This is a debit card, so I checked my bank account and find that they went ahead and charged me, even though it failed. I double checked the zip code, and of course it was correct. So then I had to wait another 4 days to get my money back.
    Just today, I thought I'd give them another chance. I thought maybe I somehow screwed up the order by entering something wrong. Go through the checkout process again, and I get the same result. I only put enough money on that account for these gaskets...so now I've got to wait another 4 days until I can call the local GM dealer to get the parts I need. :mad: :mad:
    Matt
    1998 Mystic Teal Camaro M5
    ...burn the place down? [img]graemlins/stickpoke.gif[/img]
    that sux though dude, just screw gm and order everything not by them, i bought a few things at the dealership that i really really really needed and that cost me an arm and a leg :\ forget them
    99 WS6
    13.25@104.97 - Lid + soon to be more other stock items ;D
    Originally posted by camaroextra
    tears are great lube, but its hard to get a girl to cry onto her own ***.
      No problems with them here. There are things you order from them and things you dont. Sometimes credit cards do weird things in the electronic verification process, it happens and its not necessarily their fault.
      I will order from them again. Once you go to the dealership and see what they want to charge for the gaskets you might change your mind again.
      Cp
        never use a check card to order anything online..
        -Brad
        2000 V-Star Custom 1100
        :rock:
          It's not a check card, nor is it a debit card...it's a pre-paid credit card by visa.
          Matt
            We avoid gmpartsdirect.com. Never had any luck with them. They rip you off on shipping and trick you into thinking you're getting a deal when you're really not. If you're lucky enough to have their primitive-as-all-hell online system work then you'll discover it takes 2 weeks for them to even ship the damn part.
            No thanks, my time is more valuable than that.
