prank war is on! - FirebirdV6.com/CamaroV6.com Message Board
prank war is on!
  • #16
    All i have to say is don't take it to too high of a level cause then you are asking for a even higher thing to be done to you man. So what you need to do is be creative as aposed to cruel.
    2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
    • #17
      Originally posted by G-Force:
      In Microsoft Windows, if you press the 'Print Scrn' key on your keyboard during any application it will take an image of whatever is on screen and place it onto your clipboard. From there, you can paste it into whatever application you wish...
      So here goes. Shut down any applications they have running on their computer and capture an image of the desktop, with all of it's icons, using the Print Scrn key. Open paintbrush and click Edit-->Paste to paste the image into Paintbrush. Save the image as a bitmap, and return to their desktop. Right-click the desktop and set the Desktop wallpaper to the image you just saved. Now delete all of their desktop icons. The icons will still appear to be there, but since they're only part of the image and not really icons none of them will work. Endless hours of fun as they try to figure out what happened.
      --From collegehumor.com
      Don't delete the icons, move them all off the screen.
      Another fun one I found:
      Same sort of concept, but you copy and paste the icons in paint (so that the bitmap is covered with icons). Set it as his background and randomly move his icons over one of the pictures. This way he has to click every icon to find the working shortcuts.
      <a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six</a> <br /><b><a href=\"http://www.cardomain.com/id/c_o_jones\" target=\"_blank\">Cardomain</a></b><br />--This doesn\'t change the fact that I am ~The Guru~ who still kicks puppies...
      • #18
        switch his keyboard and mouse plugs. or if you could get his IP adress, you could use this thing i found called "netdevil". google it. i tried it on some of my friends, you can do funny stuff like turn their monitor upside-down, randomly execute and stop programs, and ALOT of other funny crap. also:
        ""My absolutely most favorite prank I have saved for last. It is so simple to do and yields such nice results. Simply pop out the 'm' and 'n' key on someone's keyboard and reverse the two. Any flat tool will work. Just pry it with little pressure and they will easily come right off. Then just sit back and watch the confusion.""
        http://www.ebaumsworld.com/officepranks.html
        i know they are "office pranks" but some could still apply.
        • #19
          Rearrange the letters on his keyboard. That's always fun.
          www.RedLineVSix.com || 1996 Camaro, 15.159@92.5mph
          • #20
            Ok when he is gone get the powder tide, lift his bottom sheet off and sprinkle all over, make a decent coating. Put sheet back on, cant tell that eny is done make sure it is not too much so that is noticable. Everyone sweats while they sleep. When they do the tide seeps into the sheet on onto him, he will itch like crazy and take a shower only to get back to bed wet...hahahah makes it worse, it will take a few times till he gets the hint. We did that to get this one guy who never showered, I mean like aw eek or so between showers, stunk to all hell. Nothing harmfull will happen just itch like crazy. And ton of showers throughout the night.
            2001 Camaro A4<br />K&N air filter<br />Bone stock other than that<br /><br />(+[_]+) PSP
            • #21
              Someone did this to me lastnight. I was scared as hell. I was at my friends house and we were just leaving. I went outside to get in my car and unlocked it, then my friend called me back inside for something. A few other guys were hanging outside and I was longer than I thought. So one of them got in and stuck it in neutral and took off the parking brake. They pushed it across the street and it was dark, so I couldn't see it. When I came outside I was all mad and everything. I want to get back at them but I know if I do it will just get worse until they end up damaging my car. GRR
              2000 M5 Pewter Firebird [Monsoon stereo]<br /><a href=\"http://www.centerlinewheels.com/sub_wheel.php?mw_id=2\" target=\"_blank\">16\" Centerline Galaxy Wheels</a> . <a href=\"http://www.bfranker.badz28.com/headlightfix/\" target=\"_blank\">Headlight fix</a> . Under dash lighting . Dashmat . Headlight conversion<br />84k miles<br /><br /><a href=\"http://www.cardomain.com/id/tucsonbird\" target=\"_blank\">Cardomain</a><br />Tucson, AZ
              • #22
                My friend's Re-arranged the keyboard, but they were dumb enough to leave "F" and "J" where they were. 2 weeks later, they were like "you never fixed your keyboard yet?" I didnt notice it was broken. If your roomate can type, missing keys will not bother him at all most likely.
                94\' Quasar Blue Camaro - Gone<br />---New ride---<br />98 Silvermist GTP
                • #23
                  How about droping his hand in a bowl of warm water while he sleeps.
                  Apparently, this resluts in the victim having a little 'accident'.
                  96 Teal Firebird<br />Colchester, Essex, UK<br /><a href=\"http://www.centrestage.free-online.co.uk\" target=\"_blank\">www.centrestage.free-online.co.uk</a>
                  • #24
                    these are good ideas. We have to shut down everything before we leave. I've already done the print scrn thing, and shut down his comp. then when he leave for class I'll unplug his hdd. it'll be a 2 for 1.
                    I still want more ammo cuz this will continue. Thanks for all the good ideas,keep them comming
                    • #25
                      Does he like Orange Juice? If he does, then put some Bacardi 151 in his orange juice. Not a lot, but the orange juice will hide the taste. He'll be getting a big buzz everytime before breakfast. Then, you can do whatever you want to him!
                      <b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six</a> </b><br /><br />1998 Sport Metallic Gold Firebird A4:<br /><br />Whisper Lid, 5% Limo Tint, 30th Anniversary Side Stripes, 3\" Borla Catback Dual Exhaust, Man Fan Switch, SLP CAI<br /> <a href=\"http://members.cardomain.com/98goldbird\" target=\"_blank\">http://members.cardomain.com/98goldbird</a>
                      • #26
                        thats a good one but what if he ends up have to drive somewhere?
                        • #27
                          a horrible one would be to put dog poo in a grocery bag, and strap it to his engine block of his car. Once the car heats up and melts the bag to the engine and start to burn whats inside. Smell will come through the air vents and from the outside in. No way around not smelling it.
                          However, risk of fire, risk of being shot if he finds out it was you, the smell will not go away until it burns off. he'll prolly throw baloney all over ur car.
                          it might be a little too much though, it will prolly escalate things a lot. I always thought it would be funny though. :\
                          99 WS6
                          Originally posted by camaroextra
                          tears are great lube, but its hard to get a girl to cry onto her own ***.
                          • #28
                            Ok I have done this one a few times, its pretty funny. You take the hose that refills the toilet bowl after you flush and have it slightly sticking out the top of the toilet so after the guy takes a piss and flushes the toilet it will spray him and its a lot of freaking water. Enough to fill the tank of the toilet so its pretty funny. It creates a huge mess though so since you live in the dorms I assume you would have to share a bathroom and possibly have to deal with the clean up so it may be something that you wouldnt want to do but its pretty funny. Also make sure that the hose is just barely sticking out of the top of the toilet so its inconspicuous.
                            Alex
                            1996 Camaro RS A4<br />Flowmaster 80 Series Muffler with 2.5\" catback and cutout, SLP CAI, BMR STB
                            • #29
                              http://media.ebaumsworld.com/funnypranks.wmv
                              http://media.ebaumsworld.com/prank8m.avi
                              i thought the match idea was pretty good.
                              EDIT: after further reveiw, i realize that the second link there is really graphic. be warned!! NWS times 10
                              [ March 12, 2005, 04:34 AM: Message edited by: mike h ]
                              • #30
                                lmao that second one was great! isnt that a cky movie?
