I think I just fried my clutch - FirebirdV6.com/CamaroV6.com Message Board
  • I think I just fried my clutch
    It's 23 degrees here, and my gravel driveway is covered in a good 3 inches of ice. At the end of my 40 yard driveway is the gravel road that I live off of (also covered in 3 inches of ice/snow,) which goes uphill towards civilization. After 120 lbs of salt and feverishly spinning my tires on the ice trying to go uphill, I think my clutch is about gone. 3000 RPM in 1st gear and the tires seem to be rolling backwards :(
    Thank you, Dominic, for your old clutch. Looks like I'll be needing it a lot sooner than I expected.
    Looks like I'll be taking the Jeep down the mountain, over 200 miles to my parents house.
    ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
    driving in ice in a firebird tsk tsk
    <a href=\"http://www.sounddomain.com/memberpage/437104\" target=\"_blank\">http://www.sounddomain.com/memberpage/437104 96 Firebird M5</a>
      So my clutch is fine, but it seems my LSD doesn't work as it should. Power is applied to the tire that can spin the easiest, wtf
        The Torsen LSD needs some friction on the spinning wheel to transfer power - say it can only apply twice the torque to the good wheel as it can to the spinnning wheel. So on ice it may not help too much.
        Solution is to gently hold the brakes or parking brake to put some drag on the spinning wheel, so it can transfer more force to the other side.
        2001 Pewter Firebird Y87, M5
        Go Sabres!
          Originally posted by zlexiss:
          The Torsen LSD
          96 + Y87 = Auburn LSD
            Ooops. In that case, the diff might already have needed new clutches from the normal wear.
            Go Sabres!
