ta-dah, the rest of the house has internet, and at my whim...muhahahah.
Sure routers are nice, but my way was cheaper when I did it. (4 free network cards, $12 hub = good enough)
2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
You need a NIC (network interface card) you can get some pretty cheap at the local walmart. Then you need a crossover cable. put the NICs in , plug in the cable and couple other steps that the NIC installing will probably tell you and you're good to go
White 1992 3.1L V6 firebird<br /><a href=\"http://www.cardomain.com/id/ssj_trunks\" target=\"_blank\">Here she is</a><br />----------------------------------
do you realize how slow data transfer is over the com (serial) ports or parallel port? there is a reason it died out over 4 years ago.
Spend $10 on 2 network pci cards and get a crossover cable for another $10. now you have a 2 computer 100 mbps connection, fast enough for any game i have heard of!
or... if you have usb ports on both computers (preferrably 2.0) then get an "a to a cable" for $10 and direct connect through the usb interface.
Originally posted by C.O.Jones: Honestly, it would be better to use a 192 series. IE 192.168.1.1 and 192.168.1.2
The subnet mask will set itself to 255 by default.
Good point. You're absolutely correct.
╓<br />║ Matt M<br />║ <a href=\"http://home.austin.rr.com/morrism/3800/sunset_logo2.jpg\" target=\"_blank\">Down with the Sixxness</a> <br />║ Polo Green 1995 3.8 Camaro<br />║ intake, cat, catback, shocks, 3.42\'s, and 12\'s in the trunk<br />╙
