I've seen these for Sport Compacts roaming through Summit and Jegs...What exactly are they?
What is a "Cam Gear" and how does it work?
From what ive heard i know they are mostly for dyno tuning. Ive also heard from ricers that it can either give them better top end or take off. My cousin has a cam gear on his tibby and i didnt really see a difference from riding in it. Other then that it killed his top end.
From what i can guess from what ive heard it adjusts the 2nd cam timing.
[ July 26, 2005, 02:47 AM: Message edited by: SirShaun ]1994 Arctic White Camaro T-Tops(all options except leather)<br />80 Series Flowmaster Muffler<br />Ebay Cold Air Intake<br />Earthquake in the back known as a Kicker Solo Baric 15 L7<br /><br /> <a href=\"http://www.cardomain.com/id/sirshaun\" target=\"_blank\">http://www.cardomain.com/id/sirshaun</a>
For cars with overhead cams, you can get different cam gears to adjust the cam timing so that valves open or close sooner or later. Easier/cheaper than going with a custom cam, not as much power increase.
- Justin<a href=\"http://www.njfboa.org\" target=\"_blank\">New Jersey F-Body Owners Association</a><br />1987 Camaro LT - 400sbc, Aluminum L98\'s w/valve job, Comp XE 274, Q-Junk 750, 3.23 posi, 4.10\'s soon.<br /><br /><a href=\"http://www.njfboa.org/forums/viewforum.php?f=11\" target=\"_blank\">East Coast F-Body Nationals - August 14, 2005</a>
Pop the cover off. Adjust from -5 to +5.1994 Arctic White Camaro T-Tops(all options except leather)<br />80 Series Flowmaster Muffler<br />Ebay Cold Air Intake<br />Earthquake in the back known as a Kicker Solo Baric 15 L7<br /><br /> <a href=\"http://www.cardomain.com/id/sirshaun\" target=\"_blank\">http://www.cardomain.com/id/sirshaun</a>
- Justin
It doesn't give you more power per say, it adjusts the powerband either higher or lower. The only way it will give you more power, is if the cams aren't tuned for maximum power.
For example, my car has VVT-i(Variable Valve Timing with Intelligence), which is basically a computer controled cam gear on the intake cam. The base setting retards the intake cams for better gas milage. If the computer senses I'm putting the engine under load, IE mash on the gas, it will advance the timing on the intake cam for maximum power. This is similar to VTEC or VVTL-i(Variable Valve Time with Lift and intelligence) for toyota. VTEC or VVTL-i actually switches to a different cam profile all together which changes the timing and the lift which opens the valves a lot more.
With an OHV cam, the timing is set in stone. After the cam is ground, you can't change when the intake and exhaust valves open or close.
On DOHC motors, there is a seperate cam for intake and exhaust. With cam gears, you can adjust those two different cams to change what time the intake and exhaust ports close.
BTW putting cam gears on stock cams is pretty much useless, you might squeeze a few horses, stock cams are pretty much tuned for the most power you can get. The only way you would benefit with cam gears is with aftermarket cams.<a href=\"http://pics.projectpredator.com/thumbnails.php?album=16\" target=\"_blank\">2003 Zinc Yellow Mustang GT</a> 1 of 701<br />ET : TBD<br />But our shenanigans are cheeky and fun! Yeah, and his shenanigans are cruel and tragic. Which... makes t
