Y87 - FirebirdV6.com/CamaroV6.com Message Board
Y87
  • Y87
    Is it worth not buying a firebird just because it doesn't have Y87 with it? The car in question is this one 1998 Firebird
    I e-mailed the guy and he said before he had the flowmasters on it was a single outlet. A clear indicator of a non-Y87 bird? It is manual so all of those come with 3.42s correct? What I'm missing out on then is the quicker steering ratio and the differential. Granted I could install my own differential I have no clue as to how to get the quicker steering ratio.
    I suppose there isn't a night and day difference between a Y87 bird and a non-Y87 bird. I just don't want to go in and buy the wrong car for me. And what I want is the epitomy of stock v6 firebird performance.
    -All M5 rear ends are 3.23.
    -Non Y87 is open rear, Y87 has LSD. If you bought a used LSD and paid someone else to install, you could add that for about $450. If new, $750 ish.
    -Steering ratio isn't that big of a deal. My non-Y87 car steers and eats corners quite fine, thank you.
    -Y87 dual exhaust isn't a "true" dual exhaust anyway.
    -Y87 cars came from the factory with lower profile, higher speed rated tires. This is irrelevant because a car from '98 isn't going to have the stock tires on it anymore.
    -Y87 cars don't have the same 118 mph speed limiter because of the different speed rated tires.
    The difference isn't "night and day" at all. You can see that I added the Y87 things to my non-Y87 car over the last several months. [Better tires, LSD, exhaust]
    Condition of the car you're looking at is the most important feature, IMO. These cars get beaten to death more often than not...
    \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
      http://tech.firebirdv6.com/y87.html
      Raven
        It lists in the performance encyclopedia that the Auburn Pro series is $400 but the Zexel-Torsen T-2 Series is only $95. Couldn't I just go with the Zexel I mean i'm not creating a 12 second car.
          That needs to be changed. That was when SLP sold "take-off" Z-T, which they don't anymore.
          Raven
            That thing is OLDDDDDDDD. You use to be able to buy the Zexel brand new for $95. Good luck finding that deal now, your best bet is picking up a used one for $150ish, or just swapping a V8 rear.
            Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
              How hard is it to install the differential? Isn't the rear already set up to take it?
                There are a couple install guides on the web for the differential install. The idea of swapping a V8 rear is a good one, because it also gives you disc brakes on all four corners.
                  I thought disc brakes were standard 98-02.
                    </font><blockquote>quote:</font><hr />Originally posted by Fbody3400:
                    I thought disc brakes were standard 98-02. </font>[/QUOTE]That is true. All 98-02s came with rear discs.
                      I thought disc brakes were standard 98-02. </font>[/QUOTE]My bad, as stated above yeah they are. Typing faster than i was thinking [img]tongue.gif[/img]
                        So how hard is it to install the differential? The rear is already set up for it correct?
                          So what I'm getting from all of this is that when I put my 98 up for sale I should mention that it's a Y87??
                            I don't mean to take over the thread, but I'm looking at two firebirds on friday and they are both at dealerships. How do I tell if they are Y87?
                              look on the drivers door trim tags. The code will be on there.
                              http://www.bowtiev6.com/
                              • Manimal
                                Coil springs
                                by Manimal
                                6 days ago
                              • Manimal
                                Newby here
                                by Manimal
