Welp, I locked my keys in the car, and there is like a 1/4 of an inch of snow on the ground, and I dont feel like fidgeting around in the cold trying to get it unlocked, looks like i'll be staying in tonight. Anybody have a good suggestion to getting the doors unlocked? I had a meter stick all the way in there, and on top of the lock button, I even got it pressed down, but they wouldnt unlock. Any ideas?
Locked my keys in my car
I locked mine by mistake one night while unloading all of my fire gear. I had taken the door panel off a few times for speakers so I knew where the lock was. I went inside the firehouse and got our slim jim and popped the door in a matter of seconds. It's very easy to do you just have to try.2005 Cavalier LS Sport M5<br /> <a href=\"http://members.cardomain.com/firefighter8615\" target=\"_blank\">http://members.cardomain.com/firefighter8615</a>
if you use the remote to lock it then you cannot use the switch to un lock it for some reason. noticed it with mine.95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
DO any of you guys own F-bodies? $50 for a AAA?
-1 flathead screwdriver
-meter stick(since you have one)
-a screw
CAREFULLY use flat head screw driver to pull the window away from the frame a little. Grab it with your fingers. Put handled of the screwdriver, in between the window and the roof of the car to prop it open.
Get meter stick or other type of stick, put a screw in the end of it, at a 90 degree angle, make sure its a little secure. Reach down in the car, and use the screw to slide the lock over.
I use a stick used in banners at movie theatres, and they have screw in eye-bolts at the ends, I just move one of those, I think those are ideal(if you have one), since they are thinner, and longer then a meterstick.
[ February 03, 2005, 12:05 PM: Message edited by: shenanigans ]-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
lmao, only eric would come up with something like that...\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
Pressing the power lock/unlock button doesn't work.
You have to pry the window back and push the manual slide lock forward. I've done it with a coat hanger once. And also with a 2 ft screw driver once. Though the screw driver hurt because I had to wedge my arm in between the window and the roof.Keith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
"I ain't too big to listen to the rumors, I'm just too @#$% big to pay attention to them" - Dr. Dre
http://seppo.hopto.org/
yup, ive done this too. because of our awesomely huge windows it is real easy to do too.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
You have to pry the window back and push the manual slide lock forward. I've done it with a coat hanger once. And also with a 2 ft screw driver once. Though the screw driver hurt because I had to wedge my arm in between the window and the roof.<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
you are going to want something with an L-shape, it makes it 10xs easier to get the manual slider lock, then with something straight. IF you have a long enough "straight" stick you can reach all the way across to the opposite door.
IF you can't do that, I once broke into my 94 with a thin pipe I found laying in the parking lot, I bent the edge, and got it in the window, and used it to "crank" my manual windo down till I could reach the lock. But you need manual windows for that.
[ February 03, 2005, 01:58 PM: Message edited by: shenanigans ]-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
they've already known. you guys are the only ones i have met that haven't known how to do this (its common friggin knowledge).2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...1 week ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....3 weeks ago
