TT Stang V6 ..high 10's..video
looks familiar, ive seen the video before.
Originally posted by asdf1234:
Isn't that Shane's Buddy's car?
Follow me!
Or this
Too bad Zooomer's GTP is running 9's on a twincharged setup after only 6-7 weeks of messing around with it. :DCheck out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
Apparently he got it today. I can't get to the thread with the info, it's on ClubGP, but it's blocked here at work. :(Check out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
hahaha that was a LONGGGG time ago......the car has been down since we ran that 10.9X run. Justin has been working on his dyno trailor so not much has gone into the Mustang. He is building a motor fot it which should dip it down into the 9's.Past Ride
1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
(If you dont know me, you haven't had a V6 long enough)
Current Ride
2006 Mitsubishi Evolution GSR
www.myspace.com/shane1015
Originally posted by L32Projekt:
Too bad Zooomer's GTP is running 9's on a twincharged setup after only 6-7 weeks of messing around with it. :DPast Ride
Current Ride
I'm in the process of finding out all the mods, and I don't think it's as extensive as people may think. ;)
Edit: Here's a list
Mod list includes:
VS cam
M90/turbo for power adder with dual liquid/air intercooling all built by Stattama. Based on ZZP stage 2 IC.
ZZP trans with all the hard part upgrades
ZZP 3k stall converter
ZZP stage 1 heads
ZZP race PCM
65# mototron injectors
stock fuel pump with boost a pump
ZZP stage 2 throttle body
[ October 09, 2005, 10:07 PM: Message edited by: L32Projekt ]Check out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
all i know is it makes me want to go turbo even more.
on the 4real with looch96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
OK, here's the mods, up to date:
Engine mods include:
Stock L67 bottom end with balance shaft removed
ZZP stage 4 heads
Gen 3 M90 with outlet porting and 3.1” pulley
ZZP stage 2 L67 throttle body
65# injectors
Cometic .052 4-layer gaskets
Mezeire electric water pump
Dual breathers
Royal purple racing 11 motor oil
ARP head studs
Comp 1.7 roller rockers
XPZ cam
Roller master double roller timing set
EP fuel rails using stock FPR
ZZP Gen 2 intercooler with plastic lower ½
Machined intake
Stattama turbo kit using 1.75” tubular headers
Air to air intercooler modified for 3” inlet/outlet
ATI balancer
Stattama AC delete
ZZP alternator pulley
Transmission includes:
ZZP performance rebuild
3.29 gears with GMR 1” chain
Stattama aluminum flex plate
ZZP 3k converter
ZZP gun drilled OS
ZZP pump shaft
Stock differential (this is the same stock dif we installed in the car 2 years ago when we took out the 5th or 6th failed intense dif)
ZZP input shaft
Misc mods include:
EP fuel pump rewire
DHP custom PCM
EP ICCU
Custom transmission cooler
GMPP suspension
KVR brake rotors
Line lock
Flow charger
3800 specific Walbro pump
6 point chrome moly roll cageCheck out my stable of supercharged W-Bodies <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=136\" target=\"_blank\">HERE</a><br /><b>\'97 Pontiac GP GTP Coupe</b><br /><b>\'98 Regal GS | L67 3800 Series II</b>
