Ok guys- Now I know at lot of you are fairly knowledgable in the mechanics field. I'm very much interested in it, but not very good at it. I have an old 1988 Bonneville (it was my first car) as a back up. The heat nor a/c has worked for about a year, so yesterday I went to Napa and bought a new thermostat. I was kinda burned cuz it only cost me $11 bucks for the thermo and gasket and I thought I'd have to pay a mechanic to put it in for me. Instead of paying someone to do it I figured I'd at least try it myself. So I took the radiator hose off, unbolted the little elbow/neck thing. Pulled out the old thermostat, put the new one in and put everything back together. Took me about 45 minutes total, the hardest part was putting the elbow back on, it was a tight fit to get my ratchet in there. I finally got my tools dirty! haha. In the end nothing is leaking and I now have heat! That didn't fix the a/c, guess it needs recharged or whatever. I actually have a winter beater with heat now. I know putting a thermostat in isn't really a big deal, but I felt accomplished because I did it all by myself. You'll never learn anything unless you try it out. Just thought I'd share with you guys.
changed thermostat myself
1998 Pontiac Firebird<br />5-speed<br />Navy Blue<br />Only additions so far: Flowmaster Dual Exhaust 80 Series, K&N air filter<br /><br />1989 Ford F150<br />Alpine Green and Tan<br />300/4.9 Inline 6, automatic<br />completely stock- daily beaterTags: None
Make sure to bleed the air out of the system, if there is an air bleeder screw on top of the thermostat housing.
How to:
Run the car up to full operating temp
open hood, leave car running
use flathead screwdriver and slowly open the screw until liquid starts streaming out
close the screw
yer' done!\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
No its a good thing... I was never taught how to do things... all self taught.
hell I remember being scared to do an oil change...
since then done rear end work, torn down tops of motors, cut t-tops into my car, and much much much much more.
Gotta start somewhere [img]smile.gif[/img]-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
I always get nervous when I do work on my Firebird or anybody else.
For one thing, it's my gem. I have no problems at all with my other cars.
Thermostat was actually one of my first mod too. I got that idea from Stefan. One thing I didn't do is to bleed it.
yea it saves you money when you do your own work. good ****96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
