You know how sometimes you buy a shirt thats your size from a store you rarely shop at, only to find out that when you put it on its really about a size smaller... Well, i want to buy some clothes online since the usual places i shop at are about 1 1/2 hours away. These stores being Old Navy, Aeropostale, Abercrombie, Hollister, ect. The mall type stores. I'm just worried that if I order them online, they'll get here and wont fit. Anyone know of certain brands that you have to buy a bigger size than you usually wear?
Buying clothes online...
I buy in-store and online from Abercrombie and Hollister all the time. There's no difference in sizes at all. An XL in-store is the same XL online. You can check their size charts online if you're concerned though.1996 Pontiac <a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">Firebird</a> <br />Black, 3.8L A4
i work at abercrombie. it really depends on the shirt style. i wear a large in our t-shirts and wovens, but an extra large in our polos. what are you looking for???96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
Originally posted by j_downey50:
I buy in-store and online from Abercrombie and Hollister all the time. There's no difference in sizes at all. An XL in-store is the same XL online. You can check their size charts online if you're concerned though.<a href=\"http://www.xbox3604free.com/default.aspx?r=381546\" target=\"_blank\">http://www.xbox3604free.com/default.aspx?r=381546</a>
abercrombies clothes are cut to fit tighter than other stores, so if you want a loose fitting shirt, you will need to get a bigger size.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
