Sea Foam - FirebirdV6.com/CamaroV6.com Message Board
Sea Foam
  • Sea Foam
    Anyone here tried sea foam in their engines on here? I heard its good for cleaning the carbon out of cylinder heads, piston chambers, and fuel injectors etc. On the back of the bottle, it tells you two different ways to put it in. You can either put in into your oil or your gas. Im not really sure which to put it in. The can is one pint and im not sure if it would have an adverse effect on the oil in the motor. I wanted to put it in the oil because it claims to clean rocker arms and seems to focus on more important things in the motor. Anyway, if anyone has any input or tips when using Sea Foam let me know.
    2000 Camaro, Pewter Metallic, M5 tranny, 3.23 gears, Hard Top, <br /><br />Modifications:<br />SLP loudmouth (dual/dual tips)<br />MSD 8.5mm wires<br />K&N airfilter<br />SS hood (don\'t buy from fiberglassfabricators.com!!!)<br />Spec stage 2 clutch
    Nope, don't believe I've ever heard of anyone using it. [img]graemlins/stickpoke.gif[/img]
    Try a search in General Tech. There's 100s of posts about it, most of them locked because it's talked about so often.
    Matt
    1998 Mystic Teal Camaro M5
      and im sure this one will be too.
      Follow me!
      Or this
        yep.....probably last till the morning [img]smile.gif[/img]
        2000 3.8 A4 Pewter Camaro
          its morning now 420am EST
          99 WS6
          13.25@104.97 - Lid + soon to be more other stock items ;D
          Originally posted by camaroextra
          tears are great lube, but its hard to get a girl to cry onto her own ***.
            4:20???
            pack the bong.
            BuickThunder.com<br />\"Think out side the bowtie\"
              Make SURE you don't use it in a garage! It will smoke like a SOB and neighbors will call the fire department! Stuff works though.
              <br /><br /> <a href=\"http://www.cardomain.com/id/nitroxxx28\" target=\"_blank\">http://www.cardomain.com/id/nitroxxx28</a>
                Not again!
                  There's also a "3-point" method of doing it. Take 2 cans, put 1 can in your empty gas tank right before you fill it up, put 1/2 can in your oil, and pull your brake booster hose and let it suck up the other 1/2 can while the car is running. It will take some practice with this because if it sucks in too much at once the car will stall out. I did mine that way at 100K miles, and it ran like it was brand new after the smoke cleared...lol Also, you'll need to change your oil 500 to 1000 miles after putting it in there. Hope this helps.
                  2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
                    6 days ago
