Looking in to something like those. Not too many I can think of. Talon, Eclipse GSX, WRX, Any others out there?
AWD Automatic 4 bangers
Subaru
They have more than just the WRX.
Toyota's got some, too.~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
If you can do it, I recommend an M5 DSM over an automatic. The autos are pretty inefficient.2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
every subaru with a 4 cylinder, every 4 cylinder audi with quattro, theres quite a few.
if you want something that can eventually be built up into a quick car, dsm's are nice. however, they'll make a mechanic out of ya cause all my buddies who own them need to work on them religiously to keep them on the road. and even then, things like timing belts and turbos seem to be routine maintenance items. older subarus seem to be cheap in my area and tend to run for a while (burn oil and rust, but theyll keep running)Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
screwed-yuo-too svx, 6banger, and not every screwed-you-too had 4wd.
Why not consider updrading to the AMC EAGLE!!!111!!!!11!!1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
OMG that car is HAWT!!!1987 Buick Grand National drivetrain in my 1993 Pontiac Firebird. PT53 turbo, 212/212 comp cam, 3400 lockup converter, stock heads, Precision bar & plate FMIC with 3\" piping, 1994 z28 rearend, hotwired walbro 255 fuel pump, Nitto drag radials
subaru has the legacy gt.. detuned wrx motor.. but with a chip, it flies, and it has style!!~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
