just as title says!! i have a new job at target and i was opening boxes and well i think my keys got thrown away!!! was my only set(just bought the car) can the dealership get my key code form the door or vin number!!! if not what will have to happen?
HELP! have car, NO keys!HELP
Yes but you will have to show proof that you are the owner. it may cost you about $40 to get the new keys made.New Toy Red 94 Formula LT1
RT: .0006 60': 1.894 1/8 mile: 8.351 @ 84.89 1/4 mile: 12.974 @ 107.81
crashed Red 96 Camaro 3.8l: 14.91 @ 92.38
The ex wife's Black 98 Firebird 3.8l: 15.23 @ 88.12
They can but it would prolly be cheaper to get a locksmith to do it. I had a VATS key made for $25 when mine got destroyed. Call a lock smith.2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
They should have the tools for it.2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
yeah I 'm at work right now and I locked my keys in the car this morning when I got in...
lucky me eh?
soooo yeah, I have about 10 hours to figure out what I am going to do...
best way ive found to unlock my car if my keys are inside is to get a metal coat hanger, bend everything but the hook straight, then CAREFULLY!!!! pry back the top of the window on the side of the car closest to where your keys are sitting. slide the hook thru the key ring and you can lift the keys thru the corner of the window that is pulled back. i originally seen this done by AAA and I have used it since on my camaro whenever i'm stupid enough to lock myself out. Takes about 5-10 mins if you know what you are doing... pretty simple really...Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
yeah, but hes going to have a bit of trouble starting it after that.
also, if you go to a locksmith, are they going to be able to make the key with the resistor in it? i guess maybe they can, i dont know...
