Ok I have xp on my computer now everything running fine. However, I got a new disk with sp2 on it and I figured I would do a fresh install. But when I put it in and went threw the blue screen where it loads everything. I get to starting windows and the computer just shuts off? Anyone have a clue what’s wrong. Thanks
window xp question?
window xp question?
1998 Navy Blue A4 Camaro (Sold)<br />MODS: Performance<br />Whisper airlid,K&N Filter, TSP Rumbler & Carsond cat.<br />Apperance:Xenon Airdam and clearcorners. <a href=\"http://www.cardomain.com/id/wilkcamaro98\" target=\"_blank\">http://www.cardomain.com/id/wilkcamaro98</a><br />2002 Dodge Ram Sport Silver 4.7 v8 stock.Tags: None
sp2 is bull****. u must have ZERO spam, spyware, or virus on your computer to successfully install sp2. which unless the computer is brand ****en new.. its impossible. Last known good configuration is u'r friend96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
Funny, I've run SP2 since before it was released with 0 problems. It's been almost a year since I last reformatted, and I have no viruses or spyware.
Windows is probably getting a fatal exception. By default the computer automatically reboots, rather than showing you the STOP code so you can debug the problem. There's a hundred different things that could be causing the problem....bad memory, drivers, etc.Matt
1998 Mystic Teal Camaro M5
If you can get into safe mode (mash F8 like crazy when the computer boots), right click my computer, go to properties, advanced, then go to startup and recovery. When your there uncheck the restart windows button. Then reboot normally. Note the error code and look it up. Chances are the SP2 installation is ****ed, but it could be something else. You don't really need SP2, I tried it for a day or so, hated it so I uninstalled it. Some like it, some don't.94 Firebird 3.4 - RIP<br />97 Firebird 3.8 - In the works
well I got it to work I think it was getting to hot in there cause if I left off the one panel it worked fine so I cut a hole in the panel right were the cpu is and put a fan with a filter there.1998 Navy Blue A4 Camaro (Sold)<br />MODS: Performance<br />Whisper airlid,K&N Filter, TSP Rumbler & Carsond cat.<br />Apperance:Xenon Airdam and clearcorners. <a href=\"http://www.cardomain.com/id/wilkcamaro98\" target=\"_blank\">http://www.cardomain.com/id/wilkcamaro98</a><br />2002 Dodge Ram Sport Silver 4.7 v8 stock.
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...8 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
