I DON"T suggest running it in your oil. I have heard some people say they ran into problems with it there. But I do suggest flushing the oil with a detergent, that they sell off the shelf, if you haven't done it in awhile, helps clean a little sludge out.
Me either, I dropped a cylinder after doing that.
1995 Patriot Red T-Topped Z28 A4<br /><br />Mystery rebuild in progress.<br /><br />Soon to have 383 ways to beat KBreezy and Shane. :D
Originally posted by BiH: you probably put the whole can of seafoam in your oil :D ,I did use it in my oil with no side effects
I have used it 3-4 times no problems but I would never do it again...
there was a thread at CZ28.com people using the reccomended amount in their crankcase then shortly after the motor gets toasted, pull it apart and their oil is was like jello in certain parts.
caused problems form clogging oil sending units to spun bearings and such.
May be the minority, but I saw enough people to convince me its not worth the risk.
