Here how it goes:
1-Can change oil and rotate tires.
2-Same as 1, but can also do belt and spark plugs.
3-Same as 1&2, but can also do flushing the radiator and changing fluids on the tranny and rear axle.
4-Same as 1,2,&3, but can also change alternator, water pump, and replace radiator.
5-Same as 1,2,3,&4, but can also do electrical wires and computer.
6-Same as 1,2,3,4&5, but can also do some internal engine work: heads, push rod, rockers and so on.
7-Same as 1,2,3,4,5,&6, but can also do tranny work and rear axle.
8-Same as 1,2,3,4,5,6,&7, but can also do complete engine and tranny hauling.
9-Same as 1,2,3,4,5,6,7,&8, along with hauling the engine and tranny out, you can also do a rebuilt on both engine and tranny or even replace it with a different engine.
10-Same as 1,2,3,4,5,6,7,8,&9, but you do any mechanical work on the car plus all the body work as well.
