Originally posted by Jeanda: Does everyone in here count on Auto-zone to scan?
Autozone
And its not letting someone else "diagnose my problems"
Its instead of buying a $100+ scanner, and storing it with the rest of my tools in my apartment, and only use it twice in 1.5 years. I store it down the street at either autozone or the 600 million advanced autos.
My scanner, his scanner, they still give me a code, don't really have to be an expert to interperet a code.
My 94 3.4L, never found a scanner that worked on it. I tracked down every problem the old fashion way and was actually pretty decent with it. This board helped alot on that.
[qb] Does everyone in here count on Auto-zone to scan?
Autozone
C'MON!...are you really that shallow! Its not about being able to visually "see" a code. Its about using your head and figuring out why you are getting that code!
---94 Camaro-L32--- <br />\"Don\'t hate the playr, Hate tha GAME!!\" <a href=\"http://members.cox.net/jeanda_sd/SD_L32/SD300L32.jpg\" target=\"_blank\">http://members.cox.net/jeanda_sd/SD_L32/SD300L32.jpg</a> <br /> <a href=\"http://members.cox.net/jeanda_sd/SD_L32/100_0022.JPG\" target=\"_blank\">http://members.cox.net/jeanda_sd/SD_L32/100_0022.JPG</a> <a href=\"http://members.cox.net/jeanda_sd/SD_L32/L32flipmode.wmv\" target=\"_blank\">http://members.cox.net/jeanda_sd/SD_L32/L32flipmode.wmv</a>
Of course, around here they just tell you the code then go back inside. If you listen to the dude at autozone your an idiot. I have done and do all my own work except for tranny/clutch stuff, mainly because of time constraints, and living in an apartment.
Only advice I ever took from a dude form autozone was where I coudl get lightweight bondo that they didn't carry.
I have my own also. It's an actron 9135 or something like that.
All this talk about scanners, it makes my head spin. Which one is the best overall for my 1996 Series II 3.8 M5? I had 1 code disappear on me after changing octane levels but thats another forum lol. I would appreciate a recommendation and moneys no object but keep it under $300 for starters. I would also like to make or adjust the changes if necessary once an SES light comes back. I can get a laptop readily available if the need comes. Thanks a lot!
Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
ok....looks like a few of you do.
-knock sensor
"does anyone know what the reading should be?"
-knock retard
"what should it read?"
-BLK LRN Cell
-spark advance
-CCP Duty Cycle
"what %?"
-AIR DIVERT
"should the solenoid stay on, or switch off?"
-closed loop A/F
"enabled/ or disabled?"
-injector QDM
"whats QDM?"
.......................anyone,
[img]graemlins/popcorn.gif[/img]
hptuners, had autotap before that, and an obd1 scanner before that [img]smile.gif[/img]
00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
