Home electrical is #$#*##$## #$#$ $#(*$#($*#(* - FirebirdV6.com/CamaroV6.com Message Board
  • Home electrical is #$#*##$## #$#$ $#(*$#($*#(*
    ARGH!!!
    Finally, after almost 10 hours on this F*#*$& project!
    So I was wiring a new light fixture/vent fan combo into our bathroom today. A very simple project, no big deal, right?
    WRONG!
    I pulled the old one out, only to find that the existing wire to the switch went thru a hole just big enough for the 1 wire to reach, and it's far enough out of my reach that I can't get another wire thru it without tearing out drywall - even with a fishtape and an extra set of hands. So, the fan & light are on a single switch. First bad news.
    So I start wire in the new fan/light combo, only to find that the layout pattern of the new fixture box requres about 8" more wire than is in the ceiling. So off to Home Depo-(wned) to get some 12awg cable. Come home, splice the new wire in so I have enough wire to work with, and hook it up, hang the fixture from the mounts, run down to the basement & flip the breaker. Run back up stairs. Find that I wired the fan & light into series instead of parallel, so each got half the voltage, thus both loads were running at half-capacity. OK, simple mistake. At least it's not shorted out.
    So I run back down to the basement, flip the breaker back off, come back up, take the fixture down, wire it into parallel, hang the fixture back up. Run back down stairs, flip the breaker on, run back up stairs, only to find the light on regardless of switch position and the switch controls the fan. OK, another simple mistake. At least it's not shorted out.
    So I run back down to the basement, flip the breaker back off, come back up, take the fixture down, wire it into parallel, run back down, flip the breaker back on, run back up. Works great! Hang it back up, put the cover plate on it, only to find that I hung it about 3/4" too low, so there's a gap between the ceiling and the plate.
    By now it's getting dark, so I find my flashlight.. and run back down to the basement, flip the breaker back off, come back up, take the fixture down, hang it back up at the right height, run back down, turn the breaker back on again, and NOTHING. The entire CIRCUIT that contols the lights to half the house was out, no power to anything, including my fridge. So All the lights downstairs are out, and it's now dark outside, so my flashlight is my best friend. So run back down, flip the breaker, run back up, pull the fixture down, check the wiring, all looks good, except one of the bare ground wires slipped out of the wirenut, so I fixed that, ran back down, flipped, ran back up, still nothing.
    Now, I start to troubleshoot, all the while I'm more frustrated than a Janet Reno's blind date. Fast forward, 4 hours and 60 trips up and down the basement flipping breakers, pulling every outlet out of the wall & checking, only to find that a MOTHERF$&#*$&#* Ground-fault outlet tripped when the ground wire slipped, broke the flow to the entire f$#$#*& circuit. All I had to do was push that little f#*$#$ red button 6 f$*&$*& hours ago and I would have been on my merry way....
    Got everything back together, all the outlets back in, fixture hung back up, ran down, flipped the breaker, and POP! WTF#$#&*$#& Reset it, flipped it again... POP!
    Now I'm pissed. Run back up, take the fixture down, found that when I put part of the fixture the last time (which was like the 18th time) I pinched a wire, punctured the insulation and it grounded out to the frame of the fixture. :mad: :mad: :mad:
    Fixed that, hung it back up, flipped the breaker, came back up, and it worked, finally.
    Job that should have taken an hour, took 10.
    So here I sit enjoying a very well deserved ice cold beer at 2am.
    [img]graemlins/rant.gif[/img]
    [ October 03, 2004, 04:57 AM: Message edited by: MTMike ]
    <b>Trucks</b> <br />\'05 Dodge 3500 Dually <i>Cummins Turbo Diesel</i><br />\'98 Dodge 2500 4x4 <i>360 V8 (Wife\'s)</i><br /><b>Toys</b><br />\'81 Chevy K10 <i>Stroker/Swampers/Custom Suspension/1-Tons/Beadlocks</i><br />\'99 Camaro Z28 <i>6 Spd, T-tops, Borla</i><br /><br /><b>Real trucks don\'t have spark plugs</b>
    [img]graemlins/rofl.gif[/img]
    Teknology &gt; you
      Home projects are the shizzle, but you sir got OWNED! :D
      ---Niño---<br /><i>95\' silver 5 spd</i>
        Atleast he didn't burn the place down [img]graemlins/rofl.gif[/img]
          Great way to spend a Saturday, Mike!
          i'm glad I'm not the only one who can turn a one hour project into an 8 hour comedy of errors.
          I'll take electrial work any day over plumbing, however. That's like an art because you have to do everything "just so" or there will be a drip - drip - drip somewhere. Grrr.. Give me electricity any day because if you make all the ocnnections correctly, it will work.
          I solemnly swear I am up to no good.
            Caint wait until you wire in a light in the basement. Wonder how many times you'll run up & down the stairs out of sheer habit before you realize the circuit box is in the same room [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img]
            2013 Ram 1500 Big Horn
            94 comero 3.4
              Originally posted by camaro_speedemon:
              </font><blockquote>quote:</font><hr />Originally posted by pontiac nino:
              Atleast he didn't burn the place down [img]graemlins/rofl.gif[/img] </font>[/QUOTE]Dammit! You beat me to it!
              lol, anyways, glad you got it all sorted out Mike, I'm sure we've all been there before.
              1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
                Hey that's not too bad...
                check this: on my old car (Grand AM) I installed a strobe light kit, then I removed it later... well, everything was fine... then car suddenly stopped starting. It would not start, not even crank... so my way was to open the hood, slam it down and it would start... obviously I thought it was starter, so I replaced it... boo-fkin hoo, same problem... cost me a whole lot of nerves and visits to mechanic who had no clue wtf was up... finally, I found this ***** *** ground screw for ignition loose... just by sheer accident.. tightened it down and it was all good...
                  Man, thats just funny as hell. A simple red button.... [img]graemlins/rofl.gif[/img] [img]graemlins/slap.gif[/img]
                    ahahahahahaha you got own3d. good thing you didnt burn things up [img]tongue.gif[/img]
                    2000 3.8 A4 Pewter Camaro
                      Hahahaha, given your history man, I was expecting at least a small fire somwhere in this story. Congrats on getting it fixed though.
                      ~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
                        soundsli ke you got some good excercise today....by the time you get done with all these kidns of projects you'll prolly be down to like 8% body fat [img]smile.gif[/img]
                        White 1992 3.1L V6 firebird<br /><a href=\"http://www.cardomain.com/id/ssj_trunks\" target=\"_blank\">Here she is</a><br />----------------------------------
