Loose Change - FirebirdV6.com/CamaroV6.com Message Board
Loose Change
  • Loose Change
    I'm surprised there hasn't been a thread about it yet. For anyone who hasn't seen the video, its a pretty controversial documentary created by the research a group did on the events taking place on September 11th, 2001. It definitely makes you wonder, and surely has lead me to ask some questions.
    Loose Change 2nd Edition
    Its fairly long, but I'd recommend checking it out.
    -Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
    Re: Loose Change
    there was, it got deleted, and i will imagine the same thing will happen to this in a matter of minutes
      Re: Loose Change
      There was.
      IIt definitely makes you wonder
      Not it does not. It is retarded sensationalism. These conspiracy theorist have far too much free time.
      http://www.cardomain.com/memberpage/799659
        Re: Loose Change
        Originally posted by SpeedingFirebird
        There was.
        Far too much good pot to be thinking all their crazy thoughts
        Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
          Re: Loose Change
          I'm not particularly taking any side, and bare in mind that I am ignorant.
          What do you know that I don't that makes this video seem like such hogwash?
            Re: Loose Change
            I don't have a ton of time to respond to this, so I cannot articulate all of my thoughts.
            Basically, you can take clips and documents over 50 years, put a handful together and make it look like "evidence" when it is really coincidence. Also, they only present information to sway you one way, the do not present both sides.
            Example: Take the buildings falling like a "controlled fall". They do not present the SCIENTIFIC reason they fell that way. It's documented and well known. If the buildings were part of a controlled destruction it would have been done from the bottom. Finally, the clips they show make it look like the buildings fall neatly. They do not. They destroyed many surrounding buildings over 10 acres wide.
            Crap like this is designed to convince people w/o showing all of the evidence. It is clearly yellow journalism that attempts to look real and convincing.
            They are conspiracy "theorists" not scientists for a reason. I am a scientist; therefore, I base my decisions on facts. :rant:
              Re: Loose Change
              Right on.
