air compressor - FirebirdV6.com/CamaroV6.com Message Board
air compressor
  • air compressor
    I see an air compresser for sale at PEP Boyz its $120. Its a 10gal, 3.25 PEAK hp, 2 run hp compressor pump, max of 125psi.
    Anyone know where I can get a better compressor from?
    I guess I could find a better one at a pawn shop, but it'll be used.
    I just need it for die grinding, but mostly for using an air wrench to redo a head gasket swap. thanks
    Re: air compressor
    You need to match the SCFM of the compressor to the requirements of the tool. Neither of which you stated.
    Raven
      Re: air compressor
      i know that
      my tools operate at no more than 90 psi
      what is S cfm? S/cubic foot per minute?
      do you know any better deals? thanks robert
        Re: air compressor
        standardized cfm
        http://www.labcair.com/reference/cfm.pdf
        Visit My F-Body Page
          Re: air compressor
          i knew it stood for "standard", just thought it wouldnt be that easy
          anything else you need to know about my setup?
          I'm sure this is the compressor I'm gonna buy, I dont see anything better..
            Re: air compressor
            My 60 gal compressor was worth every cent. Everyone I know that opts for the smaller version regrets it.
            <a href=\"http://www.cardomain.com/id/sac2165\" target=\"_blank\"> CAMAROS</a>
              Re: air compressor
              i got one at home depot for $300, 60 (i think) gal compressor, and a whole bunch of tools.
                Re: air compressor
                You want cheap? Try harbor freight.
                Pep boys is about the last place I'd go looking for one, unless you get some kind of discount.
                \'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
                  Re: air compressor
                  A Zillion times correct! I also bought a 6.5hp 60 gallon compressor and it'll run any air tool on the market. I bought mine used for $200 from an auto shop who was closing.
                  Save your money and go with the largest you can afford. Smaller compressors are good for a little while, but you'll regret it when your tools are losing power due to lack of pressure.
                    Re: air compressor
                    My 25 Gal craftmans works fine. The only tool it cannot keep up with is the die grinder. No regrets here.
                    http://www.cardomain.com/memberpage/799659
                      Re: air compressor
                      costco.
                      2002 Silver Metallic A4 Firebird - All Options
                      Hotchkis STB, Custom Madrel Bent 3" Exhaust, Pacesetter Headers, Whisper Lid, FT Ram Air, K&N Air Filter, D2S HID, Baer Rotors, !EGR, !MAF, 10% tint, Parrot CK3300
                      Your Mom or My Dad?
                        Re: air compressor
                        Craftsman here, 30 gal (iirc) upright w/wheels and operates all my tools.
                        2013 Ram 1500 Big Horn
                        94 comero 3.4
                          Re: air compressor
                          if your 25 gal cant keep up with the die grinder, then I need something bigger.
                          what HP was it? I plan on useing a die grinder
                          well, I already looked at harbor freight and found some really small ones that were cheap, then I found some really big ones that were expensive!
                          The pep boys one is a better deal than harbor freights.
                            Re: air compressor
                            there are none at costco
                              Re: air compressor
                              is "peak" the maximum
                              and "run" is the average hp rating of the compressor pump?
