2011 v6 camaro engine. - FirebirdV6.com/CamaroV6.com Message Board
  • 2011 v6 camaro engine.
    DOD JUNIOR
    The LH6 isn't the only engine that will receive the benefits of displacement-on-demand. We've already mentioned that Daimler-Chrysler's Hemi will be getting some form of DOD in the near future--but we don't have exact details of that yet. What we do know is that GM is coming out with a 3.9L V-6 (RPO code LZ8) which is scheduled to first appear in the 2005 Pontiac G6.
    The "high value" 60-degree OHV V-6 will become the staple engine in vehicles which typically had the old 3100-, 3400- and more recent 3500-series engines (on which the LZ8 is based). Rated at 240hp at 5900 rpm and 245 lb.-ft. of torque at 2800 rpm, the 9.8:1 compression LZ8 will make 90 percent of its peak torque between 1800 and 5800 rpm. That compares very favorably with the venerable supercharged 3800 (RPO L67) which, in most iterations, makes 240hp at 5,200 rpm. What's more, the LZ8 does it with only 100cc more displacement, two valves per cylinder, pushrods and no supercharger.
    Like the LH6, the LZ8 will have electronic throttle control and cylinder deactivation (running on three cylinders to the LH6's four), but will also throw into the mix variable valve timing and a variable intake manifold for dynamic runner tuning. Variable valve timing will be accomplished electronically by a gear-driven camshaft phaser capable of altering timing by as much as 40 degrees. As a happy coincidence, this feature will also allow the elimination of EGR control.
    For the time being, the LZ8 will only be available in non-DOD form, but we've been assured that it will eventually appear. What's more, the LZ8 is designed to work in a rear-wheel drive configuration, which would pave the way for its use in a future base-model Camaro. If that occurs, the LZ8 would trump the '05 Mustang's base V-6 by nearly 40 horsepower while returning the same fuel economy.
    Re: 2011 v6 camaro engine.
    those spark plugs look much easier to change. haha
    '99 Camaro Y87 M5 T-tops
    Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
    Car Domain
      60*> 90*. They sound better too.
      1995 Patriot Red T-Topped Z28 A4<br /><br />Mystery rebuild in progress.<br /><br />Soon to have 383 ways to beat KBreezy and Shane. :D
        The way things are going now by the time we get to 2011 there will be 4 cyl. cars running up to 300hp. That would make the V6 camaro engine way outdated again.
        Plus considering the V6's that are coming out today, 2004-2006, there are companies like Honda that makes 240-255 hp V6, Nissan 260-297 hp V6, Toyota 240-250 hp V6, and even Hyundai made 240-263 hp V6.
        Though these engines are all aluminum, variable timing, high Compression ratio, and high revving, with smaller torque.
        GM might as well jump the band wagon and make V6 engines that's well over 300hp. Just like in the early 90's. GM made V6 that was way ahead in HP and Torque. V6 engines that are better than some of the V8's at that time. It took car companies 3-4 years to match their number. Bad thing about GM is they never bother to update themselves. Too busy with their Corvette.
        Besides, I don't think that engine is mod friendly.
          Tuners will have fun with the variable cam timing
          2000 3.8 A4 Pewter Camaro
            serp belt looks much more difficult to change tho, more componets driven, and some of the pulleys are in front of it, but still easier than some i suppose, i do like it, slap a sc on it and its ready to go :)
              Looks like an electric water pump!
              F*cking diplacement on demand?!?!?!?!!? How about NO! It didn't work in the past.... GM is CRAP.
              God, better not be backed up by one of those trannies that never shift too!
              Where does the air go in???? Behind the engine? EWWWWWWWWWWW
              Eh.... blah!
                umm ewww
                www.turbov6camaro.com
                1997 3800 Series II Camaro
                  i wonder if the shortblock could be swapped in place of the 3.4, or even use it in the 3400 hybrid swap way with the fwd alum. heads and a 3100/3400 intake, and make it the almighty 3900 hybrid it looks the same based off the picture
                  --1986 Firebird M5-- TEAM RED
                  http://www.cardomain.com/ride/2109812
                    you sound like one of sukers that bought a caddy way back w/it. :cry: :cry: :cry:
                    2013 Ram 1500 Big Horn
                    94 comero 3.4
                      Where does the air go in???? Behind the engine? EWWWWWWWWWWW!
                      The engine shown is the 3.9 in the GTP G6 so it sits sideways in the engine bay, I'd imagine if they put it in facing forwards they'll have to put a new intake on it. :cool:
                      I've driven one and I really wansn't all that impressed.
                      <a href=\"http://www.cardomain.com/id/briansr\" target=\"_blank\">97 White Pontiac Firebird 3.8 A4</a><br />Mods- 2.75\" exhaust, Dynomax muffler, magnaflow cat, SLP CAI, Hypertech 160* thermo, Fan switch<br />Suspension-Kumho Ecsta 712\'s, 32mm/19mm sway bars<br /><br />Our Lady of Blessed Acceleration, don\'t fail us now. <br />-Elwood Blues
                        Eh.... blah!
                        Dang James. You just hate it because American cars beat German cars.
                        According to Popular Mechanics, they will use this engine on the Camaro. I think just like the 3800 in the F-bodies, the intake will be put in front.
                        I read previously from the same mag. that the 3.9 is actually capable of over 300hp and still remain fuel efficient and reliable. Whether or not GM will do it is questionable.
                          Is that the waterpump on towards the top? The top pulley?
                          Is the other thing, an opti-spark type thing...
                            god i hope gm learned from their mistakes and wont use optispark
                            Car Domain
