i put a ford badge on my car and it broke down within 5 minutes!
on that note, a little humerous fact....
"FORD, atleast they circled the problem"
\"there are things known, and things unknown, and inbetween are the doors\"-jim morrison<br /><br /> <a href=\"http://www.cardomain.com/id/99NBMCamaro\" target=\"_blank\">http://www.cardomain.com/id/99NBMCamaro</a>
